Question about HP Smart Buy ProBook 6475b AMD Quad-Core A10-4600M 2.30GNotebook PC
Number lock key pad does not work from the fn
2 Suggested Answers
  • 61 Answers
SOURCE: I can't type numbers using my numbers pad.
have you tried shift and num lock
Posted on May 15, 2009
How to fix Fn key seems to be locked it is working backwards?
You have activated the number pad that can be used on a small non number pad keyboard, usually 15 inch and smaller computers. Hold the FN key and hit the num lock key to go back to the regular configuration.
Jan 18, 2015 | Gear Head Standard Keyboards KB3800TPW...
MOUSE
If it's the touch pad, it may be locked.
Or you may need to find the drivers for it.
If it's locked, to unlock it, it should have a button above the touch pad in the center that has an LED above it. If it doesn't contain a button, your computer should contain a set of FN keys, the FN keys work in conjunction with your number keys. There should be a number key with an icon of something that looks like the touch pad. hold fn + that and it should unlock.
If these aren't the case your pad could be un-lactched from the ribbon, in that case you'll need to tighten it.
If that's not the case, it may be broken.
Feb 24, 2013 | Toshiba Satellite A305-S6845 Notebook
Number pad is not working correctly
If that is newly installed OS try to check the driver of your laptop is correct. Another option, check your keyboard language settings on the COntrol panel.
Oct 06, 2012 | Computers & Internet
Where is the Fn key an a dell keyboard?
This is a simple problem, due to the size of laptops, the manufacturers cannot fit on a normal number pad as on a standard keyboard, so what they do is use a function key to turn a portion of the keyboard in to the number pad.
to get rid of this you need turn the 'number lock' off this may be a single key or a combination.
for my laptop its:
press together; the function key (normally 'Fn' bottom left) and the number lock key (Num Lock).
hope this sorts out the problem.
May 30, 2010 | Acer 91.63X07.001 Keyboard
I have a Compaq Presario CQ60 laptop and was told that I had my scroll lock activated because the numbers on my number pad only half work. The 0, ., 4, 5, 6, /, *, - all work. The 1, 2, 3, enter, 7, 8,...
Find 'fn' key (this is short for function) then find 'num lock' key in your case it must be another key with and extra label with the same font color as 'fn', this means this key behaves differently when pressed with 'fn'. When you have located both key press fn+num lock a led indicating that numeric lock is activated should go off and you're done.
Mar 04, 2010 | HP Compaq Presario CQ60Z Notebook
How do i turn off my blue keys on my inspirion keyboard
if the number lock on the keyboard is activated, then press Fn + Numlock to turn it off
Jan 09, 2010 | Dell Inspiron 1501 Notebook
KEY PAD LOCKED ON SO LETTERS COME UP WITH NUMBERS UNLESS YOU HOLD FN BUTTON DOWN CAT WALKED ACROSS COMPUTER WHAT DO I DO
It seems the cat activated the Num Lock key.
To deactivate it press simultaneously Fn +
Num Lock key.
The num lock key will be marked with 'Num Lk 'or with a a key pad icon the same colour of you Fn key.
Sep 06, 2009 | Computers & Internet
Blue numbers
Make sure Num Lock is on (the light belonging to numlock is on).
Then use Fn + Keys with a blue number on it to use the keypad.
Make sure you hold the fn-key, for each number you want to type...
If this doesn't work, try Fn + Esc. If your laptop goes to standby mode, The Function key is allright, and there is another problem. If it does not work, your keyboard may not be installed probably, or may be defect.
Please post some feedback,
Good luck
Apr 04, 2008 | Dell Latitude D600 Notebook
Number pad
There is a Fn key on the bottom left of the keyboard and a num lock key at the top right of the keyboard (depending on the model) Hold the Fn key and then press the num lock key, that should fix your problem.
Dec 10, 2007 | Zippy EL-610 Electron Luminescent Keyboard
HP Smart Buy ProBook 6475b AMD Quad-Core A10-4600M 2.30GNotebook PC Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
