Question about Samsung NV10 Digital Camera
Flash light is not opening up
My nv10 was working perfectly. but now the flash light got stuck. it is not opening up while taking pictures in flash on mode. What should I d...Please suggest.
  • Anonymous Mar 25, 2014
    flash stuck open
  • 77 Answers
Give it a few good taps with the end of your finger, this may help to unstick it. if it opensup, clean all around it with a damp (not wet) cloth...
Posted on Jun 15, 2009
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
Kodak M1033 LCD black. entire images on SD black. It powers on and makes audio. Flash works as does the the green light. In other words it seems everything works except viewing, taking, and saving...
It might be easily fixed. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 12, 2011 | Kodak EasyShare M1033 Digital Camera
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
BROKEN FLASH
the chip set in your camera is damaged.you want to change it.
Aug 27, 2009 | Samsung NV10 Digital Camera
Horizontal lines
Without knowing too mcuh about this particular model..I can say
Check your White balance options and set it to auto.
If that doesnt work..Try to reset all the options from your menu.
HTH
Aug 12, 2009 | Samsung NV10 Digital Camera
Day Light Pictures looks over exposed
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
For your camera (the A460) it's not possible to set the shutter to 15 seconds. Instead, set it to manual mode, turn off the flash, go to a darkened room, take the picture and open the door while the red and yellow light are flashing. Repeat until the shutter becomes unstuck. However, I must say that the chances are probably not very good to fix this with this method. And unfortunately professional repair will be too costly. If repeated tries do not work, it might be time to consider a new camera.
Jun 01, 2009 | Canon PowerShot A460 Digital Camera
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Apr 05, 2009 | Canon PowerShot A550 Digital Camera
Flash
What's perfect to you may not be perfect to someone else, That is why this pro grade camera offers so much in the way of adjustments. One doesn't often GET the perfect picture. More often, one must CREATE the perfect picture..
Set the flash at "0" for the most uniform pictures, and try a better lit environment and work in the 4' to 8' range. Generally, your pictures taken outside in good light, with the sun at your back will be the best. The rest, especially flash, often require some manipulation of the environment..I.E. lighting.
A perfect picture requires a perfect subject, perfect pose, perfect foreground lighting, and perfect background lighting.
So, the answer to you question is; there is no perfect setting, which will constantly produce perfect pictures.
Good Luck..
Aug 28, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
No flash pictures
by dropping you can damage the charging circuit of the flash unit. flash tube is the later part. it seems that the charging circuit of the camera is not working thus it hangs the camera when flash is switched on.
Oct 11, 2006 | Olympus Stylus 710 Digital Camera
No pictures recorded/black screen
it seems that shutter blades are stucked and are not working. when you say shutter is fully open i think you are talking about the lense cover, not the internal shutter assembly. the red light is the indication of OUT OF FOCUS SUBJECT OR FLASH NOT READY. if the shutter blades aare not open the camera would not be able to do the focusing and will flash the red light thus you would not get any image. contact the repairer.
Jun 20, 2006 | Kodak EasyShare LS443 Digital Camera
Samsung NV10 Digital Camera Logo
272 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
