Question about AUVIO Bluetooth Headphones
The blue light does not blink,it is a steady light that will not turn off and it wont pair up with my phone
I tried holding the volume+ button and the phone button but it did not reset.
    New Friend:
  • 10 Answers
The only way to reset your headphones is by charging them and pressing the call button and volume up and it will work like new.
Posted on Aug 02, 2014
  • Jorge G. Merizalde Dobles
    It works!
    The headphones don't need to be charged all the way but need to be charging at the moment of resetting.
    New Friend:
Thanks that worked!!!
Posted on May 29, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AUVIO Master
  • 1,001 Answers
Bluetooth Headphone Charm sonic ,for Gym,Runing,Exercise,Sports Amazon com Bluetooth Headphone Charm sonic for Gym Runing Exercise Sports...
Posted on Jan 11, 2017
I have my brothers droid moto phone he passed away and I want to get it hooked up to Verizon but do not know his password. How can I clean the old password off of the phone and install my password.
Hi @Rock Aduh , are we talking about the password to go in to the phone? If it is, please perform a factory reset.
1. Ensure the device is powered off.
Note If the device doesn't respond to input, press and hold the Volume Up/Down button then press and hold the Power button. When the device screen goes blank, release the Power button while continuing to hold the Volume Up/Down button then proceed with step 3.
2. Press and hold the Volume Up/Down buttons then press the Power button.
Note When presented with the Boot Mode Selection Menu, release all buttons.
3. Press the Volume Down button to tap Recovery then press the Volume Up button.
4. From the DROID triage screen:
a. Press and hold the Volume Down button.
b. Press and release the Volume Up button.
c. Release the Volume Down button.
5. Select wipe data or Factory Reset.
Note Utilize the volume keys to highlight and the Power button to select.
7. Select Yes -- delete all user data.
Note Data wipe may take several moments.
8. Select reboot system now.
Note To set up the device after the reset has completed, refer to Initial Activation and Set up.
Hope this helps. Factory Data Reset Powered Off DROID RAZR RAZR MAXX by MOTOROLA
Oct 30, 2017 | Verizon Cell Phones
I just bought a used ZTE N9130 cell phone when I charged / powered it up the screen is pattern locked. How do I factory reset this phone ?
To perform a hard reset, or factory reset, then there are a number of methods to try:
1) From the home screen, press Menu - Settings - Privacy - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
5) A final method is to enter the code into your phone's dialer: *2767*3855# This method will not give you an option to reverse the process, so be careful! This method will only work if you can boot into your phone. - See more at: http://www.phonetipsandtricks.com/tips/zte-warp/how-to-hard-reset-factory-reset-31/#sthash.9JNbyTkc.dpuf
Sep 06, 2015 | CELLULARVILLA Wallet Case For ZTE Speed...
Phone turned off itself and i turned it back on, it now says "try again in 538472 minutes"
Do a Full Reset THIS WILL DELETE EVERYTHING!!!!!!!
  1. Press and hold the Volume down and Power buttons at the same time until you feel a vibration (about 10-15 seconds).
  2. When you feel the vibration, immediately press and hold the Volume down button until you see a large exclamation mark.
  3. Once the exclamation mark appears, press the following four buttons in this order: Volume up , Volume down , Power , Volume down . Your phone should now reset and restart itself. (It might take a while for the reset to finish.)
Try again in 134600 minutes
Settings personalization
Jul 10, 2015 | Nokia Lumia 530 DUAL SIM Dark Gray Factory...
Samsung galaxy S2 mini keep restarting itself...i can t get to the menu to write codes or restore factory settings...it just resstart over and over again.....the button is not blocked and i tryed some...
Press volume up & down & power - when the phone vibrates IMMEDIATELY press the home button and after 2-3 seconds release the power button... What you're going for is that the phone tries to restart with volume up & down & home button pressed...
Press and hold both Volume UP and DOWN + POWER ON / -->( HOME ).
Select Factory reset with Volume Down button and press Power to reset. All data will be lost!
or
Turn off S6500. Press and hold POWER + ENTER button for reset menu.
Mar 07, 2014 | Samsung Galaxy Cell Phones
The volume button is stuck on vibrate
Follow this guide:
Performing a factory reset using phone buttons
1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
2. While holding the volume buttons, press the END/POWER button briefly and then release it.
3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Jan 09, 2012 | HTC Aria Cell Phone
My htc hd2 it get frozen at the TMOBILE logo "STICK TOGETHER" i profomed a soft reset by pressing the little small button pn the back of my phone and it still does the same thing
you will have to perform a hard reset and here is how you do it
Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons. While holding the volume buttons, press the END/POWER button briefly and then release it. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Thumps up if this works :-)
Sep 01, 2011 | HTC HD2 Smartphone
HTC HD2 not restarting it's stock on the provider as T-mobile. That phone is unlock.
PLease do a hard reset (factory reset ) . Here is how you do it
Aug 12, 2011 | HTC HD2 Smartphone
I have the htc hd mini, and it freezes all the time and constantly vibrates, even if i have no message and itsfully charged. It turns itself off and takes forever to load when i turn it on. The touch...
Hi you will have to try doing a hard reset or factory reset to fix this issue . PLease follow the below procedure . This will reinstall all the drivers and reload the OS
Doing a hard reset will make you loose your data on the phone .
  2. While holding the volume buttons, press the POWER button briefly and then release it.
  3. When you see a warning message on the screen, release the VOLUME UP and VOLUME DOWN buttons.
Aug 08, 2011 | HTC Touch HD Smartphone
How do i do a master reset?
Performing a factory reset via settings The most convenient way to do a factory reset is via the phone settings.
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
Ref: http://www.htc.com/www/howto.aspx?p_id=297&id=182
May 03, 2011 | HTC HD2 Smartphone
What do you fix
Mar 18, 2011 | HTC Droid Incredible Cell Phone
AUVIO Bluetooth Headphones Logo
1,107 people viewed this question
Top AUVIO Audio Players & Recorders Experts
 Mikey
Mikey
Vladimir Frolov
Phillip Hicks
Phillip Hicks
Are you an AUVIO Audio Player and Recorder Expert? Answer questions, earn points and help others
