Question about Vizio VW32L 32 in. LCD HDTV
No signal on screen.i have no manual
Need initial set up instructions . i purchased out of box
  • Benny Freeman
    Benny Freeman May 11, 2010
    do you know how to change inputs ( usually label as an av button.
    what model is it?
    President:
  • 1,077 Answers
I'll make this easy for you. You can download a manual at vizio.com
Here's the link to get you started:
http://www.vizio.com/downloads.aspx
Posted on Jun 15, 2009
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
My polariod 1700lcd TV will not change from air to digital signal how do I change this
I would have thought you could just select a different source from the remote. Can't you do that? Usually press the source button a few times to go through the different options on the screen.Need to select the analogue tv through the antenna or else digital tv through the set top box I guess so you would need to select the right source where the box is connected..
Did you do the initial set up and let it auto tune all the analogue channels when you first plugged it in.
I found this in the online manual but the preset button is one of the 3 menu items you can't select so you may not be able to follow this instruction any way.---------------------------------------------------5.Air/Cable selection
You can select the signal receiving method according to the following steps:1) Press the MENU button to enter the main menu.2) Press the button to select the itemPRESET, and press the button to enterPRESET menu.3) Press the button to select the item tv source.4) Press the button to change the item among air, catv s, catv h and cath i.6.Channel search------------------------------------------------have you checked if the parental lock is on or if some of the channels are locked out from the initial channel set up screen?
Saw someone else make a comment that they got the tv new and it had a vchip blocked when they first got it out of the box and lots of channels were locked off and took him 2 hours to figure out how to unlock it from the menu. Didn't say how he did it unfortunately.
This is the manual if you don;t have one already any ways.
http://tv.manualsonline.com/manuals/mfg/polaroid/lcd-2000.html?idRes=606769
Hope you can figure it out.
Mar 24, 2013 | Televison & Video
2004 hlp4663w component and hdmi signal error message
Chances are the analog board ( One with the Inputs) need replacement. You can get one at the following link. www.tvrepairworld.com
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
No signal when attempting to set up the TV
if you just bought it then go back to sears and have them give you a manual it should have been in the box anyway in fact i would just pack uo the set and return it for another one
Dec 02, 2009 | Venturer PLV31220S1 22 in. LCD TV
My analogue tv doesn't do anything when connected to the new set top box. The scart is connected and the aerial also. Are there some anologue tv's that can't receive the digital signal? I already have 1...
Have you checked that your aerial is connected into the set top box & not into the TV? The aerial signal has to go into the set top box & then the box will be connected via your Scart cable into the TV. On the TV you will need to select the Scart input ie. AV1. This should give you the set top box incoming signal, you might then have to tune in the box by following the on screen instructions. Hope this help.
Nov 02, 2009 | Televison & Video
Bad picture
  1. Hello boss, here is d way to make best use of it.
    step 1.Make sure ur LCD or Plasma HDTV has an HDMI port. Hopfuly u bought 1 with it, if not, you may be stuck using component cables. Not bad, but not he best. Component cables change d digital signal frm the cable box into an analog signal. This conversion allows for signal degradation. U want to keep the digital signal transmitted frm the cable company 2 go directly into ur HDTV. An HDMI cable will provide u wid this capability n with d clearest picture.
    2. Make sure ur cable box has an HDMI port. Most cable companies do not offer a cable box with an HDMI port on the initial install. You may need to upgrade by calling your cable company and asking if they have a cable box wid HDMI capability. Ask them 2 send u 1.
    3.Purchase an HDMI cable. TIP - The longer d distance between the cable box n d HDTV, the better d quality HDMI cable. This is due to degradation of d digital signal over long distances, wiz could result in a poor quality picture. ne distance over sixteen feet should be compensated 4 by using a heavier gauge HDMI cable. Oh yea, don't get taken by buying the most expensive cables. From what I have read, companies are cashing in on this relatively new technologymag-glass_10x10.gif. I bought my "gold-plated" HDMI cables from an Ebay Store, "eforcity" for about a quarter of the price found at the local electronic store. Connect one end of your HDMI cable into the HDMI (out) port on the back of your cable box and connect the other end to the HDMI (in) port on the back of your HDTV.55
    Read the instructions that came with ur new HDMI compatible cable box. These instructions will explain the download process the cable box needs to go through before use and the Setup Wizard that will program the cable box to send the correct picture format to your HDTV. If u did not get instructions, u can get them at the cable box manufacturers website. Scientific Atlanta's website: http://www.scientificatlanta.com/products/consumers/new_cableboxes.ht64. Adjust video, audio, and screen settings to ur liking. The explanation for these settings can be found in ur HDTV's user's manual.75.Push ur "source" button on ur remote control or HDTV n select HDMI. Tune to a Hi-Def channel. Most Hi-Def channels r in the 700 channel range. Check cable company listings 4 d specific channels.
  2. Have a nice time!!
Aug 19, 2009 | Sharp LC46SB54U 46 in. LCD TV
Initial hdmi tv, no signal received
If you are trying to get 'off the air' signals then you must scan for the new digital channels in your reception area (this info should be in your owners manual). If scanning doesn't find any signals, you might have to add a VHF/UHF line amplifier(s) between your antenna and the TV set or improve your outside antenna or the cable leading from it to your set. You might have to resort to subscribing to HD cable or satellite TV.
Jun 22, 2009 | Initial Televison & Video
Dark blue screen with words: Cable, Digital TV, No SIGNAL. Brand new TV.
that says it all... no signal look at your owner's manual to set it for TV
May 22, 2009 | Initial DTV-322 32 in. TV/DVD Combo
"No Signal" on ilo-26hd
Call Dish Network at 1-888-284-7116 and they can walk you through the remote program setup. Or you can look in the instruction manual for code searching using the DN remote control.
Feb 26, 2007 | iLO 2600 Television
Vizio VW32L 32 in. LCD HDTV Logo
128 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
