Question about Breville Vin170 Extreme Steam Digital Steam Generator Iron, 2400 Watt
Steam not working at full power - Breville Vin170 Extreme Steam Digital Steam Generator Iron, 2400 Watt
Philips 8300 steam generator iron keeps cutting out
I have this iron about 2,5 years, work a few times. when i shut down the steam generator the iron stays on. And now in one hour of work it shuts downs about 4 times. the lights on the steam generator are week. what main board i shuld switch?
Mar 21, 2013 | Irons
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
Hand steamer conair GS15R will not produce steam. It is on, it is full of water, the body gets warm, and it makes noises like it is steaming but nothing comes out.
Hi.
The iron steam lines may be clogged with limescale.
Try first using descaling solution to clean the lines.
Do descaling several times.
If that does not work, then the thermostat may have started malfunctioning and cutting off earlier than normal. This will cause water not getting enough temperature, and iron not steaming.
Try using a descaler product, often that can fix the problem.
Jan 14, 2010 | Conair Irons
MY iron is less than 1 year old. It has been stored for about 3 months. Now when I tried to steam a garment with it, it does not steam unless I hold the steam button down. Otherwise nothing comes through...
Sounds like there was water in the line when it was stored, which caused deposits to bild up in the line and not work without pressure. Hence having to press the button to get steam out.
Try loading it full with really hot water and a small amount of bleach. Steam all of the water out of it into the air. Clean out the resevoir with fresh water after it has cooled and try again.
Please remember to rate this solution.
Feb 19, 2009 | Rowenta Professional DX8900 Iron
No Steam
Your iron will only steam when it has reached the desired tempeture. When the yellow/orange light comes on and the dial has been set for cotton or linen it should steam, when you lower the top and push the steam lever
Nov 01, 2007 | Singer CSP1 Iron
Breville Vin170 Extreme Steam Digital Steam Generator Iron, 2400 Watt Logo
78 people viewed this question
Top Breville Irons Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Breville Iron Expert? Answer questions, earn points and help others
