Question about Philips FR931 Receiver
Reset low noise
Dell w4200hd clicking noise
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Oct 27, 2016 | Samsung Televison & Video
2008 Chrysler 300 5.7L. Oil warning light is on. Did reset. Still comes on. Much noise as if oil is not getting to engine.
The warning light is probably for low oil pressure, which is likely the problem if you are hearing engine noise.
Don't drive it until you get a mechanic to check the oil pressure.
Jun 12, 2013 | Cars & Trucks
Washer makes high pitched noise after draining
This is due to the fact that the draim pump is still running DRY and so makes the high pitch noise. Check the timer or reset to a low spin dry cycle. If not check the drain circuit power using a multimeter from the program controller unit.IF there is power and the motor makes noise then remove and check if the pump is clogged, clean and reset.
check this link:
Drain pump
Jul 02, 2012 | Amana Washing Machines
My check engine light came on and the car started stalling. I checked the oil, and there was absolutely none. I put a container and a half; drove around for 10 minutes. The noises and stalling stopped, but...
Yikes! You say there was no oil, did the 1 and 1/2 quarts bring it up to the full mark? If it did, you still had about 2 and 1/2 quarts in the engine. This was certainly bad for the motor if it was making noises and stalling. If it sounds and runs well now, you may have dodged the bullet, however, the engine took a beating from being run low or dry. You may be able to reset the check engine light by just removing the negative battery cable for about 10 minutes, hook it back up, the light should reset. If it comes back on, have it checked (parts stores will check for free) to see what is going on that causes it to go on.
Mar 30, 2010 | 1999 Chevrolet Malibu
My mazda 6, 2006 is makin a hissing noise. while in park or stopped at a red light my car idles low and sounds like it could die.? when i start my mazda it pulses( low idel? ) kinda like, cutting out. if...
Find put where the hissing noise is coming from, you have a vacuum leak. Fix that , and everything else will be fixed. After you fix it, disconnect the battery for 5 minutes to reset the computer and fuel trims.
Jan 23, 2010 | 2006 Mazda 6
Steering wheel make a noise when turn left
its due to low/no fluid level in the power steering reservoir.Check the fluid in the power steering. If it is low the car will make noise when you turn the wheel. the internal parts gets rubbed hard and noise occurs. refill the fluid and let it reset for some time then try it will get the fluency to move smooth and noise will get stopped. -------- This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Nov 03, 2009 | 1996 Ford Ranger SuperCab
Clicking noise behind dash when starting; tripometer resets to 0
the clicking sounds like the starter solenoid engaging & disengaging due to low voltage. Battery may have a short. Check voltage with engine off. Should be 12 volts. Engine running 14 volts.
Oct 29, 2009 | 2004 Ford Explorer
Dvds makes a low screeching noise and then player says "no disc"
Hi
try to replace the flex ribbon wire first then test run. let me know what happen
Thanks!
Jun 06, 2009 | Cyberhome CH-DVD 300 DVD Player
The reset button comes on for laser 72
The thumping noise is the fuel pump starving for fuel. It sould like you are having a fuel problem. NO fuel, low fuel, dirty filter.
Tom Hawkins
hawkins111@gci.net
Jan 03, 2009 | Rinnai Toyostove Direct Vent Heater:...
14 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
