Can i increase memory of intel828459G,currently 64MB need at least 128 MB. have old dell dimension 2400
  • 1,555 Answers
Below you will find the link to the technical documentation of your board. You can very well increase your memory upto 516mb. You shall save these technical details for future use.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
Posted on Jun 15, 2009
What memory (does) it use?
Jokodi Haynes,
The Dimension 8200 memory specs are listed below.
Memory
Architecture RDRAM
Memory connectors four
Memory capacities 64-, 128-, 256-, and 512-MB non-ECC RDRAM
Minimum memory 128 MB
Maximum memory 2 GB with Microsoft® Windows® 2000 and Windows XP; 512 MB with Windows Millennium Edition (Me)
Memory type PC800 (non-ECC)
Memory speed 40 ns or faster
BIOS address F8000h
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 29, 2016 | Dell Dimension 8200 PC Desktop
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
Dell dimension 2400 won't boot, just blank monitor. Power light comes on but desktop wont turn off after that just goes to amber light. The issue occurred when I replaced RAM with 128mb with 1gb in same...
This is a memory issue. First try to test it again with the 128mb of ram. Then go to the website www.crucial.com and test to see how much your system can allow to increase for memory and also see the type of memory your suppose to use. It could be that your not using the correct amount or the right memory
May 18, 2010 | Computers & Internet
Very slow also to increas memory
You need more memory. If you have windows xp you need at least 512 memory.
Jul 03, 2009 | Dell Dimension 2400 PC Desktop
How to increase memory of intel 82845G graphic controller
You will have to install a separate video card, there is no way to increase the memory of your onboard video.
Jun 15, 2009 | Dell Dimension 2400 PC Desktop
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
Would there be any 32bit PCI expansion slots on an IBM windows98?
There are PCI slots, but the processor, ram, and video capabilities are far below what modern components expect. You probably could get the wireless card to work, make sure the manufacturer has drivers for Windows 98 before you buy the card.
In my opinion you should maximize your RAM. For a Dimension 2400, Dell's manual claims the min is 128 Mb and the max is 1Gb. Not sure how you got to only 32Mb of RAM but you'll see a big improvement in performance if you increase it.
Do you have an old IBM or a Dell (the area you posed the question in)?
Jan 08, 2009 | Dell Dimension 2400 PC Desktop
Added a memory stick to my Dell 2400 Desktop computer and the monitor, mouse, & keyboard won't work
Hi
The supported Memory types for Dimension 2400 Series is PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC). Supported Memory capacities are 128, 256, or 512MB and a Max if 1GB (1024MB).
The first obvious question is does the new 512MB Memory module meet the above specification? Some Memory modules are able to steep down speed.
If it does, then first ensure the new memory module is properly installed. Take ESD (ElectroStatic Discharge) precautions or you may damage the new memory module and/or the system board.
To proceed compare the system beeps and diagnostics lights color and sequence to the Advanced Troubleshooting guide.
It is possible that the new memory is DOA (Dead On Arrival). Or there is a new fault on the system. If you have access to another compatible system, you may test the new and old memory modules. You may also swap the new and old memory modules to determine if the memory slot is at fault.
Lastly, if you remove the new memory module, does the system complete POST (Power On Self Test)?. If it does you may indeed have a DOA or incompatible part.
Mike
Jul 26, 2008 | Dell Dimension 2400 PC Desktop
Want to kow how much ram I can add and where to buy it.
Hi
Dimension 2350 Series has two memory connectors and supports non-ECC PC2100 (266-MHz) DDR SDRAM memory modules. Supported memory capacities are 128, 256, or 512MB. The maximum (total) memory is 1GB.
Regarding where you could buy? I suppose you can check you local PC store. There is always eBay if you fancy.
Mike
May 16, 2008 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
95 people viewed this question
Alun Cox
David Payne
David Payne
