Question about Epson Stylus Photo R220 InkJet Printer
Putting cd tray in epson 950
Putting the cd tray
I keep getting the message"the
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Mar 11, 2011 | Epson RX595 Photo All-In-One Printer
Epson Stylus Photo 950 InkJet Printer
the paper sensor back into tray has been out of place
Nov 18, 2008 | Epson Stylus Photo 950 InkJet Printer
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Mac OS 10.5 Leopard
As per someone elses post here:
* Source: Manual
* Size: A4
# Click Properties.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Sep 28, 2008 | Epson Stylus Photo 950 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
