Question about Olympus Audio Players & Recorders
Vn-713pc won't connect to computer
I can't find the drivers for my Olympus Digital voice recorder VN-2000PC. What can I do? I can't tranfers my audio files to my PC.
Do you need the software/drivers for the VN-2000PC or the VN-2100PC? The software for the VN-2100PC is available here: http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1270 . Select your OS and you'll find the software.
The VN-2000PC doesn't connect to the computer via a USB port. To transfer your files to a computer, connect the earphone jack to the line In (blue) jack of the computer with a 3.5mm to 3.5 mm audio patch cable. Use a program like Audacity to record the audio track during playback. Make sure to set the Audio input to Line In. (In Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click Manage Audio Devices. Then select the Recording tab and set the input device.) Then set the recording device in the software as well. Click the Record button in the software and then start the play back on your VN-2000PC. You should see a flat line for a bit then see a wave form start. If the line stays flat, you haven't set the Line In device properly.
I hope this helps.
Sep 01, 2012 | Olympus VN-2100PC Digital Voice Recorder
Drivers for olympus digital player vn-3100pc
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
Jun 24, 2009 | Olympus VN-3100PC Digital Voice Recorder
NEED DRIVERS FOR VN 4100
Apr 23, 2009 | Olympus VN-2100PC Digital Voice Recorder
I can't conect my recorder to my PC
If it is a VN-1000 it is not designed to be interfaced with a computer as there is no USB port on the unit at all. If you wish to transfer the files you can purchase what is called a compaticord or patch cable that will connect through the ear jack of the recorder to the mic jack of the computer to be able to transfer the information on to your computer.
Apr 13, 2009 | Olympus VN-1000 Digital Voice Recorder
I need instaii cd to digital voice recorder olimpus VN-3100
Apr 06, 2009 | Olympus VN-240 Digital Voice Recorder
How can I transfer files form a VN-2100PC recorder
Mar 03, 2009 | Olympus VN-2100PC Digital Voice Recorder
Cant find download software for olympus digital voice recorder vn-240
Mar 29, 2008 | Olympus VN-240 Digital Voice Recorder
27 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
