Question about Humidifiers
Rc plus thermostat
E16
I have 4 wires from my old analog thermostat. Red, blue, white, and green
Look closely at the wire terminal screws on the thermostat. There are raised letters telling you what color wire to connect to it. be careful not to touch the red wire to the others. You can blow the internal fuse on the 24 VAC transformer that supplies the voltage to the thermostat.
Mar 07, 2016 | Honeywell RTH221B 1 Week Programmable...
Does a y2081 lennox thermostat have a batteryin it
Yes it has 3 AAA batteries.
Pull it straight off the wall. Look at the back of the thermostat and replace the three batteries.
Link to manual..
http://www.lennox.com/pdfs/manuals/Lennox_Elite_Touchscreen_Manual.pdf
Sep 10, 2014 | Lennox Y2081 ComfortSense 7000 Thermostat...
My furnace runs and blows heat until the desired temperature is reached, but then it will stay off until the house cools another 15-20 degrees before kicking back on. What to do?
first , make sure thermostat is level on the wall. If o.k. try adjusting the anticipator at the thermostat. remove cover and you should see same as in picture. Move arm away from longer slightly, and try it a few times, each time before going more. If that doesn't help, it may be time for a new thermostat.motor1258_9.jpg
Jan 28, 2011 | Carrier Humidifiers
Where can I find the userguide for my Hunter 33202 carefree hudifier plus?
I think this is what you are looking for. I hope that this helps. Don't for get to rate my help to you.. Thank you.
http://dl.owneriq.net/3/3d060e88-a7a9-48c5-b125-a63b40074d7c.pdf
Dec 27, 2010 | Hunter Care Free Humidifier Plus...
How do I remove the thermostat cover to change the battery?
Many of the newer Honeywell models have a battery compartment that can be accessed without removing the thermostat.
Look for a small tab at one of the top corners of the thermostat. If this is not the case try pulling directly away from the wall at the bottom, then tilt up.
Aug 27, 2010 | Honeywell Power Humidifier: Furnace...
Humiditstat control
Hello harley,Easiest way do is Replace thermostat with a model that has humitistat functiion.Honeywell has a nice one.Adding a seprate control is complicated & sometimes cant be done at all
Mar 31, 2010 | Honeywell Power Humidifier: Furnace...
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
Oil Furnace Problem
Hello Genna,
I am not a furnace guy but I may be able to give you a few ideas of things to diagnose the problem and get it resolved. First off, I assume you have a thermostat that you use to to turn your heat on. If it is a generic ( meaning : non programmable model) then you should be able to try this simple test. Remove the cover ( typically they snap on) around the thermostat so you can see the control mechanism inside. You should see few skinny wires ( similar to those used on a telephone wire) solid copper in various colors.. When you rotate the dial on your thermostat to call for heat, there is a small glass vial that has a drop of mercury ( which is electrically conductive) in it that makes contact and shorts two control wires together ad that is what calls for heat on your furnace. When the temp inside the room where the thermostat is reaches the tempertaure you requested, the bimetal mechanism either contracts or expands to reposition that glass vial to shift the mercury off the contacts and your furnace shuts off... That is the basics behind how your thermostat and furnace work ( generally speaking) If you can identify the two wires inside the thermosat that are shorted together when that vial of mercury shorts them inside it.. you can temproarily unhook them ( they are low voltage.. normally 24 Volts or less) so no worries about getting ashock or anything.. and short them together for a minute or two.. by doing that... your furnace should turn on and heat should flow.... Once you start your furnace this way.. unhook these two wires and your furnace should shut down .. It may take a minute or two ( depending on the control for it) If it doesn't..then your problem is on the furnace side and you may need to get the furnace control system serviced or replaced.. if it does shut down, then your problem is your thermostat and thats a simple replacement.. Also.. make sure the thermostat was properly leveled on its base.. The position of the thermostat ( meaning level) will dictate when that mercury makes contact and your furnace switches on.. OK..I tried to explain the works of this to you but here is a link to a Honeywell site that explains it in simpler terms.. The part about shorting the two wires together and then opening them will aid you in identifying where the problem actually is.. here is the link: http://homerepair.about.com/od/heatingcoolingrepair/ss/thermostat.htm
Hope this helps you more than confuses you..
Regards
Sep 19, 2008 | Honeywell Power Humidifier: Furnace...
Replacing thermostat for central heat and air/ not humidifier
rh and rc should have a jumper between them.connect red to either.y=yellow g=green w=white and do not use the blue.your new stat will run on batteries.
May 26, 2008 | Honeywell Power Humidifier: Furnace...
Furnace
I would guess from the info provided that you only have two wires going to your thermostat which would explain why the fan switch doesn't work on the thermostat. You can bypass the thermostat as a first step in troubleshooting. After that it depends on the type of furnace, standing pilot or electronic ignition...
Nov 29, 2007 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
65 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
