Question about Samsung RB2155SH Bottom Freezer Refrigerator
Door sensor keep flashing
Sensor keeps changing numbers
Door ajar keeps flashing evan though the door is close
Good Afternoon Friend,
I understand the door ajar light keeps flashing even though the door is closed on your Frigidaire freezer, model# FFU17K1CW. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave the model number of your appliance. Hope this is helpful.
-Best Regards-
WP
Jul 10, 2014 | Frigidaire 16.7 cu. ft. / 473 liter...
Oven wont work unlock door meesage keeps flashing door unlocked
The model number would have helped us give you specific advice, but without it we'll give you generic advice and say it may be a door switch issue.
See our help file on door switches here.
Jan 16, 2013 | GE Microwave Ovens
Output speed sensor keeps failing.
comment on the code numbers you are getting as there are TR sensor/ s, VSS sensors and TCM module that can all read wrong and it is possible that you are changing the wrong sensor
May 27, 2017 | Ford Explorer Cars & Trucks
Hi, I have an LG front loader I think the number is 1074fhb. For the last few weeks its taking several hours to finish a short wash it keeps starting and stopping every minute or so flashing DE and...
'DE' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor, becoming apparent with the extra movement of the washer actually working, requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 24, 2011 | Washing Machines
I have liftmaster professional garage door opener. it opens ok but does not close with remote and light keeps flashing on garage door opener. I checked both sensors and seems like the sending sensor light...
If your sensors are not pointed at one another the light on one of them will go out. Tweak them a bit. If you cannot get the light to come on then your sensors are bad.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Chamberlain Garage Door Opener Transmitter 300MC: Light keeps on flashing on the motor...
how many flashes
1-safety sensor wire broken
2-safety senor wire shorted or reversed
3-door control or wire short
4-safety sensors mis aligned
5-motor overheated or bad RPM sensor
6-circut failure, bad logic board
May 17, 2010 | liftmaster Chamberlain Garage Door Opener...
Liftmaster formula 1 garage door opener keeps "bouncing" open
If the door reverses when it hits the floor it is traveling too far. Locate the 'down limit' control on the side of the motor unit and turn this in the opposite direction of the arrow printed on the cover. Some tweaking will most likely be necessary. You can always recognize a sensor problem because the main light will flash 10 times. If the main light isn't flashing it isn't a sensor problem.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door light flashes, dome light flashes, locks keep trying to lock
My Neon did this.....The door sensors were messed up and i just ended up taping pennys to the little knob.....It was a idea from my co-worker who had a Neon and had the same problem....
Apr 20, 2009 | 2000 Plymouth Neon
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Samsung RB2155SH Bottom Freezer Refrigerator Logo
15 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
