Question about Toshiba E-Studio 2540c Copiers
Does not scan
Printer indicates that the scan has been done but it cannot be traced on the computer
Printer won't scan because it's out of ink
Unfortunately, all-in-one printers are printers/copiers. The scan to a computer function is a secondary function and the unit has interlocks to keep it from being damaged when the ink is out. There is a way to print with only one ink cartridge in place but this only allows print jobs from the computer. The copy and scan functions are locked. For details, see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01673672&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3742086#N2374 . See the section on Ink Level Indicator (!) and the bottom notch of the indicator blink fast and the Workaround: Print in ink-backup mode
You need a stand-alone scanner if you routinely want to scan to your computer without a printer ink level OK status report.
I wish that I had better news for you.
May 23, 2012 | HP F4480 All-In-One Printer
How to trace and release scanner lock on Canon MP810 printer
There's a lock switch, left side near the scanning glass.
Lift the cover ( 1 ) and
switch the lock switch to the open padlock indicator ( 2 )
For online support on the MP810, look here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp810
Jul 22, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Check Engine illumination indicator comes on ocassionally when
That light indicates that your car's computer has an error message awaiting you. To find out what that message is you must have the computer scanned. It used to cost up to $100 to have a scan done at a dealership but now AAMCO repair shops and some auto parts chains scan for free. Get a free scan if you can and when you have it scanned ask them to reset it which will clear the memory and end the light coming on again unless there actually is a problem. Joe
please rate my answer as very helpful. thanks
Apr 24, 2010 | 1997 Hyundai Sonata
How do i scan to my computer
As long as the printer/scanner is hooked up to the computer, you should be able to put the document on the glass face down, close the lid and press the scan button. The HP screen will pop up on the computer screen, don't mess with that, just let the document scan (it should show you the progress) and once it's done, it will ask you if you want to scan something else or be done. If your done, click done and then it will open up the HP window and show you what you scanned. To retrieve the scan, I always go to start, my documents, my scans and look for the current month and year, open that folder and then you have access to the document you just scanned. Hope this helps.
Mar 02, 2010 | HP Deskjet F340 All-In-One Printer
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Jun 18, 2009 | HP Photosmart C7280 Laser Printer
My Lexmark P4350 printer is not scanning images to my computer?
To scan a document, please follow the steps given below:
1. Go to "Start," "All Programs," Lexmark 4300 Series, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
May 11, 2009 | Lexmark P4350 All-In-One InkJet Printer
Can't receive applications for scanning
Go to www.lexmark.com and click on the downloads. Download your printer configuration again to your computer. When computer advises that you already have the software just indicate that you are updating or fixing. Once this is done your problem you should be able to scan. This problem occurs often when you switch to wifi.
Oct 14, 2008 | Office Equipment & Supplies
Hello, I have just acquired a second hand Konica Minolta Dimage Scan Elite 5400. The utility software works fine. However, when switching it on, the green indicator light by the on-off switch does not...
All the comments I've seen made regarding similar symptoms to your were related to the setup of the device. Apparently the device is very finicky and I have heard many people say that the installation process for the scanner has caused a lot of people issues.
From website:
  • Dimage Scan must be executed before turning on the scanner for the first time.
I suspect that the device won't be properly recognised by the system without the software already being installed and configured before the device is attached. I would remove the device, uninstall any trace of it from your system, and try again with a fresh install.
Jul 31, 2008 | Minolta Office Equipment & Supplies
HP 3180 All-in-One
check printercartridge indicator lights blinks on and off replaced both cartridges
Jul 28, 2008 | HP Photosmart C3180 All-In-One InkJet...
Toshiba E-Studio 2540c Copiers Logo
14 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
