Question about McCulloch MC1246 Handheld Steam Cleaner
Steam is not coming from steamer
I have a aquamark am680 portable steam cleaner problem steamis not coming. how to fix it
I have a scunci ss 1000 hand held steamer cleaner. Its been used and given to me from a friend. The steam comes out the trouble is the steam is not hot, just luke warm. how can I fix it myself.
Try descaling it with CLR. Add CLR and water, turn it on but not fully to produce steam, just get it hot. Leave it for an hour. Empty that out and out some more in. Get this up to steam for 10 minutes, switch off, leave it for an hour and empty it. Fill and rinse out twice. Fill with water and see if it is fixed.
Nov 09, 2015 | Scunci SS1000 Handheld Steam Cleaner
RONSHESTACK@AOL.COM
Scunci International
2200 Byberry Road
Hatboro,PA 19040
Google search should provide a lot of options for obtaining the brush's but don't forget EBAY as it has been sometime ago but I had bought brush's for my steamer threw then. Good Luck!
May 25, 2014 | Scunci SS1000 Handheld Steam Cleaner
Aquamark AM680 potable steam cleaning System. I tried it but the steam is not coming out. Kindly, anyone has a solution? Thanks
hi there sorry i dont have a solution i'm looking for one, did you manage to know the problem, i have the exact same one with the same cleaning steamer, thanks
Aug 04, 2013 | McCulloch MC1246 Handheld Steam Cleaner
Aquamark hand held mod.am680 not steaming why
hi there did you find a solution i have the same problem thanks
Mar 01, 2013 | McCulloch MC1246 Handheld Steam Cleaner
My H20 mop steamer is not working it gets hot but no steam coming out
see this ccauses and use the common sense God bless you
nspect your steam cleaner's belts for loss or damage. Damaged belts can cause the brushes to stop rolling or the spray mechanism to stop functioning. To fix a damaged pump or brush belt, first unplug the steam cleaner. Refer to the user's manual to determine the specific location of each belt. Order a new belt directly from the manufacturer's website, or from a local home improvement store, if necessary.
Sep 19, 2012 | Vacuums
I have had an Aquamark AM680 steam cleaner for some time without opening the box. Now I can't find instructions for it.
It sounds like the pump that pumps the water to the heater is faulty. Try the non-return valve on the pump it may be sticking.
May 27, 2011 | McCulloch MC1246 Handheld Steam Cleaner
Parts and accessories for my Euro-Pro Shark
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories heatman101
Jun 04, 2010 | Euro-Pro Shark SC-505 Handheld Steam...
Steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Apr 19, 2008 | Scunci 52001 Handheld Steam Vacuum
McCulloch MC1246 Handheld Steam Cleaner Logo
27 people viewed this question
Top McCulloch Vacuums Experts
JoeVacs
Are you a McCulloch Vacuum Expert? Answer questions, earn points and help others
