Question about Vehicle Parts & Accessories
Dist ht leadsreplacement diaghpram vw1600classic 2001 model
Leadds removed firing orde out
My dodge truck the fireing was 180 off i put it back like the computer said and now it will not take the gas what do i do
Does the truck start and idle. If so you will need to move the dist. forward or back to set the timing on the engine. Sounds like you got it to run by resetting the dist. to number one in the firing order but did not set the time after setting the dist. Hope this helps.
Jul 03, 2016 | 1997 to 2001 Dodge Ram 1500 Truck...
Need firing order for lincoln94 mark vllland diagram plz ,Jose
images for firing order lincoln ls v8
Question LS V8 Firing order - Lincoln vs Cadillac Forums
www.lincolnvscadillac.com/forum/showthread.php?...LS-V8-Firing-orde...
Sep 14, 2012 - 17 posts - ‎3 authors
Firing order on 2001 LS V8 Bank 1 & 2 1-5-4-2-6-3-7-8 ??? 1) Can someone draw/show me a picture on how that looks when facing the front of ... firing order from 95 dual coils to plugs
Aug 2, 2012
'05 LS V8 firing order and coil installation?
Nov 19, 2009
Firing order?
Mar 20, 2008
What is the firing order for a 2000 LS V8?
Nov 23, 2007
More results from www.lincolnvscadillac.com
Jan 08, 2016 | Cars & Trucks
How to replace the distributor and line it up the correct way
With ignition OFF, remove the dist cap , do not remove HT leads from cap or plugs just move to one side ,turn the crankshaft with a spanner on the crank pulley drive nut until the rotor arm is pointing directly towards the front of the vehicle, mark the position of the rotor on the distributor body with a dab of paint and also mark the position of the body on the engine block infront of the distrbutor,remove the distributor , i believe it's just 2 screws that clamp it in place ,transfer the mark from old dist to the new dist and aling the rotor to this mark, then fit the new dist to engine and aligne the marks from the new dist to the mark on the engine block and tighten down , refit the dist cap , to get an exact distributor timing you should now use a timing light to check the timing marks line up , if they are slightly out just very slowly turn the distributer until the marks are aligned , hope this is of help
Jun 07, 2015 | 2002 Nissan Xterra
97 350 vortec will not get fire
My bet is your crankshaft positioning sensor.
Aug 10, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
Where do wires go from coil pack to distributor cap and where else 1990 chevytruck 350
coil HT lead to centre contact on dist cap ,the remaining HT leads go to the spark plugs you will need the firing order to get them on the correct plug follow this link may have to research site for your year vehicle
1967 1972 Chevrolet Spark Plug Wiring Diagrams
Apr 04, 2014 | Cars & Trucks
350 chevy misfiring
check the ht wires for a crossed set check the firing order as there are two wires that out of sequence will cause this problem. To check firing sequence go to google and type in firing order for chev/gm 350 engine and it will give all the details.
Jul 12, 2013 | Boating
Can not dile long dist.
Buy a long distance call card and use that. There are plenty of website that sell these.
Oct 18, 2012 | Computers & Internet
I need the dist. firing order from dist. to plugs. Dist was removed and need the correct positioning of the plug wires on the distributor
Looking at the front of the box 1 2 3
Looking at the back of the box 4 6 5
This is looking at your ignition coils while standing at the front of your van. Hope this helps.
Aug 02, 2008 | 2001 Mazda MPV
Vehicle Parts & Accessories Logo
14 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
