Question about Kenmore 24 in. 17052 / 17054 / 17059 Built-in Dishwasher
Low water level when"filled" - below heating element
I have a 3-year old Kenmore Elite 17052 that has gradually been cleaning poorly with a good amount of power detergent still left in opened cavity after cycle is completed.  This weekend my wife noticed that the dishes were not washed at all after a complete cycel.  I repeated the cycle and monitored the performance.  I noticed that the top spinner sprayer wasn't rotating and only a small amount of water was dribbling out of the top sprayer.  Then I noticed that the water level during the middle of the wash cycle was well below the heating element.  I added about 1.5 gallons of water so that the water level covered the very hot heating element.  After that I resumed the wash cycle and verified (by opening the door quickly) that the washer was operating as expected with the top sprayer rotating and spraying as designed.   Here are my questions:
1) What are the possible causes of the dishwasher starting with such a low water level?
2) If the inlet valve is defective, can I purchase a replacement from you?
3) Until I have this problem repaired, it seems like I can limp by by simply adding water early in the wash cycle.  Is this OK or is there risk of secondary damage?
Thanks - Loren
  • Loren59 Nov 01, 2007
    Fixed it last night.
    Removed the water inlet line and flushed it - no problems - plenty of pressure.
    Removed the plastic screen/trap just above inlet line attach point and found it was plugged with rust particulate from my galvanized pipe that feeds kitchen.  I recall that occassionally, I need to tap the debris out of the kitchen sink faucet aerator so I guess it built up over 3 years and plugged my inlet.
    After cleaning and reassembly it works like new with strong spray and plenty of cleaning power.  I'll need to do it again periodically.
    Thanks for the advice - Loren
  • 640 Answers
Does the water line going to the unit have a filtration system on it?the filters may be clogged.check the wash arm holes for seems to be low water pressure or the solenoid valve that energizes and lets the water flow may be obstructed/defective.if your unit has a float make sure its clean and moves freely.
Posted on Oct 31, 2007
  • 290 Answers
You most likely do have a water valve problem. You want to be sure it is not a problem with the supply line or valve.(maybe someone got under the ink and turned the valve partially off) The valve has a screen in the inlet that may be clogged. Remove the valve and remove the inlet fitting from the valve and try rinsing it out in the sink.
If nothing is in the inlet screen you will probably have to replace the valve. We are not allowed to sell parts on this site but you can go to and click on parts, enter your model number and look up and order from there. You will need the complete model number from the decal just inside the door of the machine.
As for adding water. The machine fills and drains several times during the cycle and you will have to add water at each fill.
If the problem is not corrected you will burn out the heating element fairly quickly because it is running more than it should.
Hope this helps and post back to let me know what you find out.
  • Michael  Lindley
    Michael Lindley Oct 31, 2007
    Also, if you do find trash or sand in the water valve, Get a piece of rubber hose that will slide snuggly on to the water line coming to the dishwasher and run some water through the line into a bucket or the sink to flush anything else out that may be in the line.
  • Michael  Lindley
    Just wanting to follow up on you dishwasher and see what you found out.
Should the water level be above heating element
The full water level will be 1/4 to 1/8 inch below the heating element. The water fills on a timed basis so the exact level depends on incoming water pressure.
Mar 06, 2012 | Kenmore 16372 / 16374 / 16379 Built-in...
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Flashing or blinking green clean light 7 times?
This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light 7 times.
The failure can be wide ranging here are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Here is a link for instructions on sump clean out
Poor cleaning or noisy Whirlpool KitchenAid or Kenmore
General Dishwasher washability
White powder hard water calcium residue
on Apr 25, 2010 | Maytag MDB8959AW Builtin Dishwasher
I have a Beko D 2731 FW its about 4 years old and recently it has begun to leave a gritty deposits. I think this may be due to the top spray arm not running as freely as it used to. I would appreciate any...
Here are a few things to check.
* Worn wash impeller (depending on design). Test by placing a glass upright in upper rack with full charge of water in the basin. Run dishwasher for 30 seconds. Glass should fill up. If not, replace wash impeller.
* Debris caught in spray arm holes. Remove spray arm and clean out with water and compressed air.
* Heating element burned out. Check water temp during wash--should read between 130 to 140 F.
* Insufficient water fill in basin. In most models, proper fill level is just up to the heating element. Much less than this will result in poor cleaning.
Hope this helps.
Sep 08, 2009 | Beko Dishwashers
Dishes on top shelf are not comming clean
Check these things out.
Aug 12, 2009 | Whirlpool DU1055XTSQ Built-in Dishwasher
Kenmore Elite Dishwasher not cleaning well
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Jun 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Water level below heating element and element does not appear to heat
Make sure the drain hose high loop is installed properly, normally you have this in the sink cabinet high up. Otherwise the water inside the machine may drain "by itself", leaking through the inactive drain pump during the wash cycle and cause this and other troubles.
May 24, 2009 | Kenmore Dishwashers
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 17052 / 17054 / 17059 Built-in Dishwasher Logo
233 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
