Question about TruTech Televison & Video
FIND A PLACE TO BUY A REPLACEMENT SCREEN FOR MY Trutech PLV16320VM 32" Thin LCD Monitor
NEED TO REPLACE THE SCREEN Trutech PLV16320VM 32" Thin LCD Monitor
  • TruTech Master
  • 3,320 Answers
A replacement screen plus labor would be about the same as a new monitor.
Posted on Mar 27, 2014
4 Suggested Answers
  • 367 Answers
SOURCE: TruTech PLV16190 no picture, no sound
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on Jun 17, 2008
  • 367 Answers
SOURCE: NOTHING COMES ON
Open the back of the TV,and look at the can shaped items called capacitors on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.Most of the time the big black capacitor on the power board goes bad,and bottom bulges out,but sometimes it is the other capacitors as well.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Feb 11, 2009
  • 367 Answers
SOURCE: was watchin my trutech 32
Did you get this fixed?Does it still turn on?Please let me know.Thank You very much!
Tyler
Posted on Mar 03, 2010
Broken screen
To begin your fix, you'll need a few simple tools and a replacement LCD screen. For tools, I recommend a screwdriver with a variety of small bits, such as a Phillips #00 and a Torx T5. It's also a good idea to have a few thin metal blades or plastic spudgers. These are really handy for removing the trim that surrounds the screen.
As for the replacement LCD, you should be able to buy one either from the laptop manufacturer's authorized parts dealer or a third-party supplier. Depending the screen, they usually cost between $50 and $250 dollars-more if it's a high-end display or you buy an OEM replacement. Regardless, you'll want to buy a new screen that matches your broken one exactly. The only sure way to do this is to remove the broken one.
After disconnecting the power supply and removing the battery, carefully examine the bezel around the screen. You'll need to remove this bezel to access the screws that hold the LCD panel in place.
On this laptop, several rubber cushions hide screws, which hold the bezel in place. I'll need to remove these cushions and the screws that are underneath.
With the hidden screws removed, I used a thin metal blade to pop loose one of the bottom corners and worked my way around the bezel with a plastic spudger.
Feb 17, 2013 | Computers & Internet
Were can ifind a power module for atruetech 32
You shouldn't have to buy a whole new board.Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Feb 20, 2009 | TruTech PLV16320 Television
T.V. or monitor
can u give me the input details.if u have a vga out then u can go for a external tuner.
Dec 26, 2008 | TruTech PLV16320 Television
Very likely have blown fuses and capacitors in both the power supply and the backlight inverter sections. Repair is best left to a technician unless you are tech savy and able to use a soldering iron.
May 03, 2008 | TruTech PLV16190 Television
Televison & Video Logo
46 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
