Question about Amana DD01E - DigiDoor Occupancy Sensor For DigiSmart PTAC
Digidoor 2 lock not working
Door still opens when lock is attivated
How can I get my cell phone attivative
dialing ##72786# from any android sprint device forces hands free activation ... for other carriers the numbers may be different
Mar 30, 2015 | LG Cell Phones
How to open a deadlocked rear door.
Hi. remove the rear seat and door pad. You can access the lock through a small hole, break the top inner corner of the lock and it will release the dead lock and open the door.
Jan 29, 2014 | 2004 Volkswagen Golf
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
No sound
http://www.orgsoftcom.org/file7njs-motherboard.htm
Feb 28, 2013 | Chaintech 7NJS-ZENITH Ultra Motherboard
Received forms for the phone but not the acct pin number to attivate
Please take this matter up with your service provider or the dealership
Jul 02, 2012 | Kyocera Jax Cell Phone
No power to truck, key locked in ignition
Is the battery dead? try charger, battery is okay but when you turn key nothing happens and key is jammed? Key won't turn? not much information you provided, but if key not working and battery is good sounds like the ignition cylinder has failed and needs replacing, i would not recommend for a novice as dis-assembly is and reassembly is not easy and requires a few special tools and if mistakes are made could attivate air bag, deactivate air bag or short electronic components
Jun 09, 2012 | 2005 Chevrolet Blazer
Right rear child lock is on the door but cant get the door open
Child Locks will stop anyone on the inside of the car from opening the door. If the child lock is on then the door can only be opened from the outside of the car. Of course the main door lock must be off just as any door must be unlocked to be opened from the outside.
Now if you do not want the child door lock to be on then you must first open the door from the outside with the main lock open or unlocked. Look at the space that is covered when the door is closed. There you will see the lever that turns the child lock on or off. Simply move it to the off position.
Good Luck.
Jun 22, 2011 | Toyota Highlander Cars & Trucks
Back door wont open.
Are you moving the child safety lock or the door lock? Only the door lock itself should prevent the door from being opened from both inside or out. The child lock is typically a switch on the door near the door pin halfway down the door.
Sep 22, 2009 | 1995 Toyota Avalon
Air conditioner will not cool   fan works ok but compressor wont come on
hELLO THERE:
I would get it serviced by a authorized dealer
sounds like the refrigerant level is low or your compressor is is bad.
Aug 15, 2009 | Heating & Cooling
Nero startsmart serial number
If you obtained/purchased this software legally then it should have come with a sticker on the CD slip or on a manual somewhere inside the box.
Jan 30, 2009 | Ahead Software Nero 6.0 (60045) for PC
Amana DD01E - DigiDoor Occupancy Sensor For DigiSmart PTAC Logo
27 people viewed this question
Top Amana Home Security Experts
Lawrence Oravetz
Are you an Amana Home Security Expert? Answer questions, earn points and help others
