Question about Juki TL-98QE Mechanical Sewing Machine
Needle keep beaking while sewing
Its happening ever time
My 2003 Brother sewing machine is needle keep on breaking when I try to sew
http://www.sewingandcraftcorner.com/why-does-my-sewing-machine-needle-keep-breaking
If it continues to break needles, most likely the machine has been knocked out of time. Search for sewing machine timing or take it for repair.
Mar 22, 2017 | Brother Sewing Machines
How do I adjust the bar that holds the needle? I ran over straight pins and now the needle keeps hitting the plate
If you are not using a brand new needle, install one now. If there are still issues, the machine has been knocked out of time (happens when hitting pins!).
Search for sewing machine timing or take it for service.
Feb 25, 2017 | Sewing Machines
Needle keeps hitting throat plate, even with new needles, and clean machine. It started happening when I was sewing on wool.
Could be the timing or the needle bar is out of alignment. Probably best to take it for service.
Jan 08, 2017 | Sewing Machines
Why does the right needle keep breaking in myloc 634d
I agree with John Smeed It could be that the needle is bent or in the wrong way if it keeps on breaking it must be hitting the throat plate or it's timing may be out( a pro job) Also check the needle is in as high as it can go.
Apr 19, 2014 | Janome MyLock 634D Mechanical Sewing...
I have a singer 3116 sewing machine
here are some suggestions
change the needle--make sure it's turned the right way when inserting
the new needle into the needle bar holder
check for burrs on the needle plate and in the bobbin area
try a different thread, some thread is just not very good
Oct 18, 2012 | Singer 3116 Simple
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
Needle keeps breaking Model 150 Euro=Pro Sew Machine
broken needles can happen if you are pulling the fabric through rather thsn letting feed dogs move it, or if stitch setting needs a wide hole foot but you have straight stitch foot on. could also mean timing between needle and shuttle is out of sync.
or needle size is too small for weight of fabric you are sewing.
check out www.sewing.about.com for needle size info and use new needle for each new project.
if yoy suspect timing out take to technician for fulk service.
Jun 16, 2011 | Euro-Pro Sewing Machines
I have a Disney Brother SE-27OD Embroidery Sewing Machine When I am doing the embroidery the needle comes out I put it in as tight as possible but it keeps happening from time to time.
Make sure you have the flat part of the needle to the back when putting it in and that it's (preferably) a Schmetz embroidery needle with the red band either 75 or 90 or a Schmetz universal 80. Make sure when you install it you can see the top of the needle in the needle slot and all the way up so it's hitting the post before you turn the screw tight. Check the screw each time you sew to make sure it hasn't shaken loose from embroidering.
Dec 13, 2009 | Brother SE-270D Computerized Sewing...
How to adjust tension on Toyota RS 2000 sewing machine (CB series
Hi
I found a free manual and parts for my Toyota 9090 on this site. http://www.aisin.fr/index3.php?language=en
The only problem is that the manual is in French but some are also available in English. I found it useful for the diagrams etc.
Try the online guides as well as they give help on adjusting tension, replacing bobbins and needles etc.
Nov 15, 2009 | Sewing Machines
Juki TL-98QE Mechanical Sewing Machine Logo
16 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
