Question about Chi Mei Corporation CT522A 15" LCD Monitor
LCD Flatscreen monitor CMV CT-522A
Hi, I am trying to find out if there is a built in microphone in the above monitor.  I was told that there was but I can't seem to get it to work with Skype? Can you help me?
0 characters
1 Points
What power adapter, what power supply should I buy as I lost the last one
see its model number and buy another with this model number.
these numbers must be same completely
Apr 08, 2016 | Wintergreen CMV CT-723A 17" LCD Monitor
I cant get a picture on the screen, all it says is no signal found.
first off it needs either an antenna or a cable hooked to it and the the input set to that and a channel scan done Monitors are not normally used as a TV however .as they do not have tuners built in
Mar 05, 2016 | Chi Mei Corporation CMV-221D LCD Monitor
Can I purchase a replacement stand for my chimei 222H monitor? If so where?
I have broken the mounting arm of my Chimei CMV 222H ...
Nov 12, 2012 - ... the mounting arm of my Chimei CMV 222H monitor, can you getreplacement arms? The locking mechanism - Chi Mei Corporation CMV-222H 22 inch LCD Monitor question. ... Video; Photos; Link; Replacement Parts. Add.
Repair Kit, Chimei CMV 221D, LCD Monitor, Capacitors ... > ... > Capacitors, Inc.
Dec 15, 2015 | Computer Monitors
My Son Bought Computer For me & Set It Up. No Instructions ARE Available. Does This Computer HAVE Hidden Microphone?
If your "computer" is what you have posted, it is not a computer at all, rather it is a monitor. Here is the manual for the monitor in question it does not have a built in microphone, however, if you were to provide me with the computer type, the computer might have one. Or, if you told me the Operating System (Windows XP / Vista / 7) I could also tell you how to find out if the computer comes with a built in microphone.
In short: What you have requested information on is not a computer, and it does not have a microphone.
Oct 18, 2011 | Dell E153FP 15" LCD Monitor
What size power supply is used
it uses 19V AC power supply adapter.
Dec 31, 2010 | Wintergreen CMV CT-723A 17" LCD Monitor
My laptop no longer detects my CMV 946d monitor. I am running Windows 7 and have upgraded all my drivers.
Temporarily, set your LCD screen-resolution to 800 by 600 by 60 Hertz.
The video on a laptop has three settings:
* output only to internal LCD screen
* output only to external monitor
* output to both
Toggle the control through the above settings, to find if any works.
If so, change the screen-resolution to 1024-by-768, and try again. Try again with 1280-by-1024.
Mar 01, 2010 | Chi Mei Corporation CMV-946D/A Monitor
Is there a built-in microphone in the monitor?
It does not come with microphone.It has only built in speakers.
Nov 05, 2009 | Sony SDM-HX93 19" LCD Monitor
Problem monitor
Hi, Sounds either a backlight problem (inverter or tube light) or the display interface. Since you have confirmed that it is your LCD monitor, your best bet perhaps is to seek the services of a qualified professional. Should you venture in doing it yourself (DIY), You need to open up the casing. A step by step procedure is better illustrated here . The working principles of notebook/laptop displays are nearly identical to your LCD. Hope this be of some help. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 25, 2007 | Amptron CMV-922D 19" Monitor
First post is misleading...sorry..not one pin bent bb.but none were bent (typo) sorry
It could be the monitors invertor board has gone bad. Call a local computer shop and tell them you need a new invertor board for your monitor and see what they say. Write me back and let me know.
Jun 25, 2007 | Wintergreen CMV CT-723A 17" LCD Monitor
No Video
Did you take the monitor out and put it back in before the pin was bent? Or did it just all of a sudden blank out.
Jun 24, 2007 | Wintergreen CMV CT-723A 17" LCD Monitor
Chi Mei Corporation CT522A 15" LCD Monitor Logo
305 people viewed this question
Top Chi Mei Corporation Computer Monitors Experts
Jax Planet
Jax Planet
Roshan Rijal
Roshan Rijal
Are you a Chi Mei Corporation Computer Monitor Expert? Answer questions, earn points and help others
