Question about GPS
GPS unit finds satellites but wont navigate or show lat/long etc
I have a generic windows CE based GPS/hand held PC unit that is able to locate upto 12 satellites and get signal strength in the 80-98% ranges from all of those sats, yet it can't determine lat/long/alt position data. When I try to use any navigator software they all show a location I was at over a week ago. Hardware reset has not changed anything. Any suggetions would be greatly appreciated.
    President:
  • 1,111 Answers
Not knowing what brand you have, most gps allow you to set your location then try and sync to the sats. have you tried that
Posted on Jun 15, 2009
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
It wont navigate
Can you please provide us the brand and model of this GPS unit so we cna help you better....
Oct 21, 2008 | GPS
Latitude & longitude
Here is the way to find the Lat/Lon Info on TomTom.
Tap on main screen. You will be taken to Main menu 1 of 2. Tap on the arrow. You will move to Main menu 2 of 2. Tap on Browse map. You will see the lat/Lon info on the bottom left hand corner (of a selected location) Tap on another location and you will see that the lat/Lon will change to that of the newly selected location. You can use the slider on the right hand side to zoom in or zoom out so that you can get the Lat/Lon info of far off locations. However, for this purpose, google maps would be a better option. But if you know the address, use the find button which will give you easier access to Lat/Lon info.
May 02, 2010 | Tomtom XL 330S GPS Receiver
I know the GPS coordinates of a place, I want to be. How do I enter those to start finding a route from where I am?
I am assuming this is a Quest or Quest2 GPS.
Using the map screen use the larger 4way "navigation" button on the front panel and cursor the screen pointer to the location you would like to save. You may need to zoom in on the location. At the bottom of the screen you will see the "lat/long" displayed. The further you "zoom in" the more precise you can get with the "lat/long". Once you have the pointer at your desired coordinates, hit the "OK" button. This will bring up an address or some other feature name. If there are multiple choices, simply pick the one that is most appropriate and again his "OK". At the bottom of the screen you will see 3 "buttons" (save, find near, and route to). Select "save". Now you will see a screen with several windows that contain the lat/long data, perhaps an address, a map icon, and the name you selected in the earlier screen. You can again use the large 4 way "navigation" button on the front panel to switch between the displayed fields. This will allow you to select a map icon such as a house, store, marina, or whatever. You can then use the "nav" button to select the lat/long window and make any final adjustments to the lat/long data. You can also move the cursor up to the waypoint name box and change it to whatever you prefer. Once you have all of the data fields to your preference on this page, you can use the "nav" button to cursor down to "OK" at eh bottom of the screen and then hit the "OK" button on the front panel. The waypoint should be stored with the correct data in the GPS.
Feb 10, 2010 | Garmin Quest 2 GPS Receiver
What if my Garmin 255 W doesn't recognize my address. Google maps can't find my house either. Can I tag the GPS coordinates? Thanks
Yes Tagging is the only way you can set home base Go to the satellite Icons and read the Lat long and then enter them into the box and name it as your location.
If its not on google then it wont be on your GPS Maps are 12 months behind most paper mkap books This is becauise all the data has to be converted to so many formats for different brands and additional features.
Please rate our help to keep the service online++++Thanks for using FIXYA
Sep 21, 2009 | Garmin nuvi 255W GPS Receiver
My gps saids i am always in new york even though iam in maryland never moves from new york
If it is constantly on a singloe map location and never cuts in to navigate thjen suspect that
1) the antenna is afunctional, disconnected, or not working to lock onto satellites.
2) The chip that locates and communicates with the satellites is dead.
If it always shows a particular location when started, but does navigate to where you ask it to take you, but always returns to the base location when tuened off and then on. The program in your home address or in SETUP program your location and time zone to have it always start in Maryland.
Jun 07, 2009 | Pioneer AVIC-N3 GPS Receiver
CP32 MKII GPS & MGL-3 ANTENNA
Yes, you need to set it all up again. I would hazard a guess that the Map Datum is set wrong, you want a NAD which is North American Datum and NAD83 is the most recent. Next set you starting location. For Map Units I use the UTM coord System as it is in meters. You can use Lat/Long which many people find easier to use.Your hand held should be able to let you choose via State and then town. Then you can create detail maps on your computer and its best to remove your mem card and insert it into your card reader and save the map details to the card. You can connect your hand held to the PC via a USB cable, but this may be harder so save the detail maps to depending on your software.
Where I am located I get calls from miners who need to setup their hand held and then learn how to set way points so they can update their mining claims accurately. UTM makes this much more accurate due to it being in metric units.
Regards,
Worldvet
May 26, 2008 | Simrad GPS
Locating Satellites
This particular unit does take a long time to initialise. Try seitching it on at home and leaving it somewhere exposed to the sky ( not inside etc) It may just need to find out where in the world it is before it can start directing you where to go. If this fails - does your car have a windshield aerial for radio receptionor some kind of electric demisting which may interfere with the signal ?
Mar 12, 2008 | Garmin StreetPilot i3 GPS Receiver
Problem with gps not connecting.
I have Google maps for Mobile working on Mio P550 with GPS Program Port: COM9.
GPS Hardware Port to COM2, baud rate 4800.
http://blogs.msdn.com/windowsmobile/archive/2006/06/07/620387.aspx
Dec 24, 2007 | GPS
Locating satellites
Hi cassyd
I have 2 questions in order to help.
1) It can take longer than 30 seconds depending on where you are, how long have you waited for it to acquire?
2) Are you holding the unit verticle while you wait for it to acquire?
If you know your lat/lon you can type that into the position screen while you are waiting for it to acquire, sometimes that helps.
Oct 27, 2007 | Garmin eTrex GPS Receiver
GPS Logo
117 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
