Question about Exercise & Fitness
Health stream gs102tm with e08 after approx 15 mins use
Was attended to by techs several times with no resolution. Boards replaced etc Company ended up supplying a new one and left the faulty one behind.
  • 120 Answers
SOURCE: Technics amp su-vx800 goes in to protection mode
yes it can, it sounds like its over heating, make sure that your product is able to get fresh circulated / cooler air
if it already is, then it probably is a faulty product.
Posted on Nov 23, 2008
  • 58 Answers
SOURCE: Reddy heater 165,000 runs for approx 15 to 20 min.
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Posted on Jan 13, 2010
Sebin
  • 712 Answers
SOURCE: sub zero 650
It is the newly adopted power saving technique. There's nothing to worry about it.
Posted on Apr 21, 2010
richroth
  • 9472 Answers
SOURCE: Have AMCORAIRE mini-split purchased in
Try this link. They will be able to help you with your concerns.
The FixYa Team
Posted on Dec 28, 2010
SOURCE: tractor stalls after approx. 15-20 of run time (1957 farmall cub)
Could you be having a fuel supply problem? I have a 1957 Farmal Model 100 and has its own problem caused by moisture building up in the distributor SLOCITYJOHN
Posted on Sep 18, 2011
Hi my traxdata cd900 recorder has just developed a problem. Ive been using maxell cdr's most were fine but lately:- a) optical failure error occasionally occurs b) will happily record approx 15 mins...
First to confirm if its a transport problem play a CD from track 1 to the last. If it is not getting stuck and smoothly plays till the end -- transport is OK. The same laser unit which reads the disc also writes. But when it writes the laser intensity is several times higher and the unit runs very hot. And old unit will start to misbehave due to the heat. TIME FOR REPLACING THE DRIVE UNIT.
Mar 10, 2011 | Audio Players & Recorders
What temperature to roast a boneless pork loin? No recipe in booklet
Hi there.
Most recipies suggest 350 degrees for a pork loiin, approx 25-30 mins per pound. Once you are near the end of the cooking time check the center of the roast with a meat thermometer. It should read 170-180 degrees to make sure it's thoughly cooked.
And don't forget to let it rest, covered for about 15 mins before slicing so the juices re-distribute.
Dec 29, 2010 | Cuisinart CVR1000
Outside compressor won't turn on
Possibly an electrical fault,
Check there is a demand from the indoor unit, all time delay relays functioning, and PCB boards operating correctly, may be an inverter fault. I would advise a HVAC company to attend site as these can be difficult to diagnose over the net.
all the best
Jul 05, 2010 | Heating & Cooling
Picture has alot of lines in it went you turn it on takes 10 to 15 min. to clear up
I do not have good news for you---if it has lines etc and clears up after several minutes--usually as it gets worse it takes longer and longer, you have a bad HYPER board--very common in these sets--board is now only available on an exchange basis--means board has to be removed and sent out for rebuild/repair.
Toshiba no longer sells this part--I just helped someone else here yesterday with a slightly different model with the same problem--he was very savvy and I sent him a photo of the board and the 10 surface mounted caps that go bad--not a job for most do it yourself people--what goes bad here are several surface mounted caps on the Hyper board--they dry out from the heat and age...
To make matters worse--most of these boards are soldered in--there is a national company who can repair/rebuild the board in your model: part number for the rebuilt board is: 23148024
This board costs about 220 dollars not counting labor to get it our and shipping etc.
The person I stepped through the repair did it himself for about 25 dollars in parts cost.
The company that does this kind of repair is PTS electronics
Let me know if you have any questions or need advice--I am here to help people--I cannot always give good news but I would bet you have a bad Hyper board.
REGARDS, SD TECH
Oct 16, 2009 | Toshiba 57H82 57" Rear Projection...
Can't process health savings account debit cards
Health savings cards like flex cards are special cards. Generaly the processing compnay needs to mark othe box set for private label cards. If your processing company has already done this. The next step would be to call the 1-800 number on the back of the card ask them what the bin ranges are or if you need to submit any special info to your processing company in order to process the card. Once you have obtain the info contact your processing company again ask to speak to a supervisor or a Senior Tech inform of the info you obtain from the card company.
Dec 04, 2008 | VeriFone Omni 3700
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Takes 15 mins to fill tank
This happened all the time with my van and then with my taxicab. the culprit is a combination of a slow angled fill tube in the car, and the new safety things on the gas pumps. What the attendant had me do is angle the pump so its not completely inside the hole, but just about the whole way so theres no suction, and making sure its still secure.
May 12, 2008 | Equinox (210120)
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
