Question about Lexmark CS510de color laser printer
Maintenance kit in display
How to clear maintenance count
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Some models if you hold down the enter or mode button for seven seconds should clear also should be in manual or check with who carries that model
Posted on Mar 27, 2014
Resetting for replaced MK kyocera fs 1135
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
May 26, 2015 | Kyocera Office Equipment & Supplies
HOW I WILL GO IN SERVICE MODE OF A PRINTER
Clearing the Maintenance Count and Service Message: HP LaserJets servicepin.jpg
If the display panel on your HP LaserJet reads "Perform Printer Maintenance", "Perform User Maintenance", "Maintenance Kit Low", "Maintenance Kit Very Low", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count.
Oct 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
T630 clear counter
The following will reset the maintenance count after you install the maintenance kit, you can not reset the printer total page count. Press and hold down the [Select] and [Return] keys while powering on the printer, hold these buttons until the display reads "Performing Self Test." If the display readds "80 Schedules Maintenance", press the [Go] to continue past this message and access the Configuration Menu. Press the menu button until the display reads "Reset Maint Cnt" on the second line of the display and press the [Select] button. The top line of the display should now read "Reset Maint Cnt" and the second line will read "Reset" and press the [Select] button. This will reset the counter. To exit out of the "Configuration Mode" cycle the power.
Apr 15, 2013 | Lexmark T630 Laser Printer
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
Mar 02, 2011 | Office Equipment & Supplies
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
How do i reset the maintenance count?
1. Select Reset Maintenance Count Configuration menu.
Mar 30, 2010 | IBM Infoprint 1532 Laser Printer
Reset maint counter
Page 3-17 of IBM's service guide
Mar 25, 2010 | IBM Infoprint 1352 Laser Printer
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Mar 24, 2010 | HP LaserJet 4345mfp Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
1. Select Maintenance Count Value from the Diagnostic menu.
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
screen.
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
Getting an display in the printer.
If you have the manual there is probably a section about this. It does sound like some parts may be wearing out and the printer is asking for new ones. Check out this link: http://www.printertechs.com/tech/maintcount.php A snip from the info there: If the display panel on your HP laserjet reads "perform printer maintenance", "perform user maintenance", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count. For example the laserjet 4000 has a 200,000 page maintenance interval. Once you reach 200,000 pages the error message appears and you need to reset the maintenance count to zero to make the message go away.
Jun 15, 2007 | HP LaseJet 4350dtn Laser Printer
Lexmark CS510de color laser printer Logo
132 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
