Radio keeps seizing when it gets hot
SOURCE: radio audio muted and cd changer gives message no cd changer c320
Hi, Joe here to help. The cd changer is at fault. You need to replace the changer. The system is on a fiber optic loop which cuts out the sound if can not complete that loop.
SOURCE: MBZ E320 CDI (2003), The CD, Radio and navigation system not work
Your radio/nav system needs a code. Go the your dealer's parts department , give them the VIN of your car( should be free $0). Punch in the code through the car radio and your radio/nav system should work right away.
SOURCE: 2003 Mercedes E32O with a machine gun door lock
you have to replace door lock completely , there is small plastic gear on electric motor which moves locking mechanism and seems that gear is broken, but it is not available as separate part.
SOURCE: How do I remove my 1997 Mercedes E320 factory radio
the radio should pull right out. use 2 picks to grab the sides and pull gently.
