GE adora front loader stops mid cycle E38 error code
  • 3 Answers
SOURCE: Ge Adora Front Loader
If you have not already done so, clean the filter behind the panel in the front bottom of the washer. Remove the three philips head screws to get the panel off. Unscrew the plastic filter on the right hand side (use a shallow cake pan to catch any water). Remove the filter and clean out the pens, pencils, change, lint, etc... and put back in. All should work well after this. Thanks, Greg
Posted on Jan 03, 2008
esbee0522
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
SOURCE: GE Adora Front Load Washing Machine Problem
I had a similar problem...with the added issue of the door not locking at all. I cleaned the filter and all is well. However, it took me hours to find the 3 screws everyone was talking about The screws are at the very bottom of the washer, under the lip, facing front. If your machine sits on a pedestal drawer like mine, they are located between the machine and the pedestal. I hope these pics save someone a little time...
Posted on Aug 27, 2008
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 193 Answers
SOURCE: I think I need to reset my front loader (adora GE)
Unplug unit, Plug back in.Rotate control knob to correct Model number.Press and hold start key till beep is heard,press power key to reset
Posted on Oct 30, 2009
Water remains in hose and smells
Front loaders are known for bad odors. Run an empty cycle with double bleach and let the machine totally dry out, with the door OPEN. The bleach will kill the mold spores and letting it dry out will prevent more from forming.
Dec 19, 2012 | GE Wh12x10309 Heater for Adora Front Load...
I have an lg front loader washing machine...it keeps stopping mid cycle and gives a troubleshoot code of oe...i cant find my owners manual and the lg site is awful....can you help me?
OE is drain error..Most likely problem is partially blocked pump filter...This is accessed via the small door at floor level...Unscrew the pump cover and clear the filter..Any water in the machine will flow from the pump cover...Empty the machine first...Leaning it back can help....Good luck....Nomess
May 14, 2010 | Washing Machines
I'm so not adoring my adora front loader right now!!!! I know about the cleaning the filter! (Thanks GE!!) My new problem is... when in the wash cycle it is making a HORRIBLE noise. Any suggestions???
try opening the door and lifting the inner drum up, if there is lift in it give it a spin with your hand if it grumbels the main bearings have worn out,, and its not a cheep job to replace them,
Feb 24, 2010 | GE WSXH208A Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Oct 13, 2008 | GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Stops mid cycle
that's the washing machine version of going on a walkabout, no? just kidding.
E9 suggests that the line is getting clogged. the filter pulls out(see user manual for that option) and you might want to consider running it with baking soda solution in warm water or hot, once or twice to get rid of that odor.
Mar 11, 2008 | Samsung WF337AA Front Load Washer
Dec 15, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
