Cannot connect to my cable modem wifi router
My wifi computers laptop and ipads can dtect the bigpond2991 signal but wont connect even after resetting devices and networks previously was working well and would connect automatically
  • 3,320 Answers
Contact big pond.
Posted on Mar 31, 2014
  • 556 Answers
SOURCE: I cannot detect my router
A first logical step would be to take your laptop to another wireless location and see if it will work there (you could also take the your wireless unit there to test it). Likewise invite a friend with a wireless enabled machine to visit you and see if they can see your wireless unit. There are three different types of wireless devices in common use A, B, G you need to know which your machine uses and which the wireless receiver uses and assure there is a match. Some devices support multiple types A&G, B&G and A&B&G as long as one matches between the wireless adapter and wireless router/access point assuming the others were not configured off the test should be valid.
Posted on Dec 07, 2007
Ryan5443
  • 336 Answers
SOURCE: unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
RCF
Posted on May 28, 2008
Teis
  • 340 Answers
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
Posted on Nov 23, 2008
  • 20 Answers
SOURCE: Problem between my Qwest actiontec modem and D-link router
You need to sign into the dlink router and check the status tab, to make sure that the router has picked up the modems IP address. it sound like it hasn't, and is just assigning lan IPs to the client machines, butd oes not have a valid WAN IP to the internet.
If it hasnt got a wan ip, you want to do a hard boot on the router .unplug the router ONLY for 30 sec, and power back up the router only ...not the modem this should allow the router to find the modem IP
Posted on Feb 16, 2009
SOURCE: Cannot connect Belkin F5D8233-4 Router to Mac Laptop
Hi, I had the same problem with my MBP and the best solution I found was:
Dissable the Wlan security and use Mac Address control only for the wireless. This will keep your network secure anyway and you can connect normally.
The only inconvenience is that when you want to connect other computers to your wireless you have to enter its MAC address on the list.
Remember to set the list as Allow.
Posted on Apr 28, 2009
Keeps loosing wifi signal
Try resetting your wireless router. Power cycle it through.
Symptoms:
lost Internet access on all devices
unable to go online
no Internet connection on router
router Internet LED symbol is amber
To powercycle your home network:
Turn off the router by unplugging it. If you have a modem and router in one device, turn it off then proceed to step 3.
Turn off the DSL or cable modem for three minutes.
Note: Some modems are equipped with a backup battery. If your modem have one, please remove the backup battery to completely turn off your modem. For common cable modems equipped with backup batteries, please see Performing a full reset of cable modem with battery backup
Turn off all computers attached to your network.
Turn on the DSL or cable modem first and let it boot. Let it complete its connection to your ISP before proceeding to the next step. One of the indications that the modem have completed its connection is by seeing a green light on the modem. If you have a modem and router in one device, proceed to step 6 after it connects to your ISP.
Once the modem completes the connection to your ISP, plug in the router. Let it complete its power on test before proceeding to the next step.
Restart your computers.
Jan 09, 2015 | Computers & Internet
Connect cable box to laptop
The Xfinity Cable Service is also an Internet service provider then you need a cable modem with a built-in wireless router.
Check with Xfinity and if they are also an Internet Service provider then they can also supply this cable modem/wireless router.
Jan 10, 2013 | HP Compaq Presario V5204nr Notebook
Does not wierless work in xp computer and 2 ipad.
Are you using a laptop? If not, the computer that you are using should capable of connecting via wireless connection. And the Modem /router should be transmitting wireless signal. If you can successfully connect via wifi, then all of your wireless end devices should be connected via wi fi a as well. check your local network for issue isolation.
Dec 30, 2011 | 2wire (2701HG-B) Wireless Router
Hello, my Ipad hase Wifi message,but cann't be connected to Internet.
If your ipad is connected then it might be that your router needs to reset or your internet is down. Just unplug your modem and router for 5 seconds then plug in and see if that helps it. Check if your computers can connect to the internet.
Mar 23, 2011 | Apple iPad 32 GB WiFi Tablet PC
My router can no longer connect to my xbox live. It began as a problem where i had to restart my modem in order to get connection on either my laptop or xbox but now, only my laptop can be connected to the...
you need to register the router to your internet provider so that the modem will always give an internet connection to the router even if the router will be reset.
from that the xbox should follow through and connect to xbox live if you have an open NAT type.
Sep 14, 2010 | Linksys WRT160N Wireless Router
Wifi can dtects signals, but no internt
Maybe, the router is not allowing the connection to the internet. It can also be that the cable from the modem to the router is not placed on the right slot.
Jun 12, 2009 | Toshiba Satellite U305-S7448 Notebook
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
