Question about Vacuums
Ezivac vacuum packing food saver won't seal !
Yes, my Ezivac from Hillmark Industries (I purchased it in Australia)does vacuum all right but it won't seal. It appears that the sealing part is not broken or damaged. We haven't used it much, frankly, and we are careful with our kitchen appliances,so we are a bit dismayed ! Especially since I bought an ANOVA sous-vide cooking machine a few weeks ago, so it is all the more frustrating. Boo ooh ooh ! Can you possibly help ? I thank you in advance !
SOURCE: lumina vacuum food sealer will not seal
Rang the info. number. I did not do this before because it was after hours.
The solution was simple, apply pressure with finger to lid and press start button. Evidently the plastic lid distorts when closed and does not make electrical connection. Works OK now.
Posted on Jul 20, 2009
  • 25 Answers
SOURCE: my Rival food saver does not vacuum air out
We discovered we were not moving the bags in far enough to be grabbed properly. After pushing in the bag before closing the unit we found it started sealing properly. This was on an older system, so be sure the bags you're sealling are between the black rubber rectanglar sections before closing the door.
If this is for a canister, be sure the rubber around the lid is seated properly. The rubber can be removed, cleaned and wiped dry. Clean out the lid and dry it too. Reseat the rubber seal and try again... Hope this helps.
Posted on Apr 24, 2010
  • 30 Answers
SOURCE: I purchased a Seal-A-Meal roll
On most models of vacuum sealing systems, you cut off the roll the size of bag you need. Slip one open end of the bag just on top of the heating element over it about 1/8-1/4" and press down the lid to seal the bottom of the bag. Fill the bag and then place the open end far enough into the vacuum cavity over the heating element and close the lid and press down and hold until the cycle finishes. If you don't want a vacuum, just put enough bag material to cover the heating element but not into the vacuum cavity. Hope this helps
Posted on Jan 03, 2011
SOURCE: Leaking Solution Tank/Seal Install - Hoover Steam Vac
Not sure this will help, but we have a Hoover Steamvac F5843 and our valve seal seemed to have shrunk so the tank was leaking. Bought a new seal and had the same problem. How to install? There weren't any instructions or pictures of the part(s) involved in the manual. Online there were a few pics but nothing helpful. After careful examination of the existing part and where it was supposed to be, I removed the original off the valve stem, placed the new one on it and carefully pressed the valve stem with the seal into place. It didn't look quite right and we were thinking "now what?". My wife and I got the idea at the same time...install the clean water tank (with the stem & seal in the bottom) back onto the steam cleaner. I took it back off to see what the stem & seal looked like afterwords and voila...the seal was perfectly inserted where it should be and the tank no longer leaks! The 'peg' that presses up on the valve stem pushed the seal perfectly in place.
Posted on Mar 26, 2011
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: How do I fit the exhaust pre filter seal
    We recommend having the seal you described installed by an authorized technician. Please call us at 0800 298 0298 (UK) or 1-866-693-9766 (US) so we can provide further assistance.
    Best wishes,
    Jessica
    Posted on May 25, 2012
    Cannot get it to vacuum.
    Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
    Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
    I have wasted quit a bit of the bags because the food saver is not sealing completely. It leaves a 1/4 to a 1/2 inch unsealed therefore I can not vacuum seal. What am I doing wrong
    Try making a seal with nothing liquid in bag, check seal on bag after. If seal looks good it could just be liquid getting on seal area causing it not to seal. There are tips online on how to help prevent this (example: placing rolled up paper towel sheet). If seal still looks bad than you may have a bad spot on the heat seal wire.
    Jan 23, 2016 | Vacuums
    MY FOOD SAVER HAS BEGUN NOT VACUUMING. IT SEALS BUT DOES NOT GET THE AIR OUT LIKE IT USE TO
    Does it hum as though it's vacuuming? If not, it's probably broken - the vacuum pump is out. It's cheaper to get a new one than attempt to get the old one fixed. If it hums, then replace any hoses you find or the foam around the drip tray.
    Dec 06, 2014 | FoodSaver V3230
    The progress light on the food saver is flashing red
    The heater bar is too hot. Allow it to cool for a while before resuming sealing.
    Oct 15, 2014 | FoodSaver Tilia 801 Food Saver Vacuum...
    My vacmaster pro 160 does not seal bags
    Try with a different bag ( I have the same problem, the bags are not the same) if still not working, the you have faulty pump
    Mar 14, 2013 | Ary Vacmaster Pro 160 Food Saver 87640
    My Rival food saver does not vacuum air out
    Apr 19, 2010 | Vacuums
    Vacuums Logo
    75 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
