Question about Sharp LC52E77UN 52 in TV
Power and opc blink twice then opc 3 times tv will only stay on for minute
TV will start up but will only stay on for a minute or so.. Once off takes 5 min at least to convince it to start again.. Have checked cable box etc. narrowed issue to TV
    Top Expert:
  • Sharp Master
  • 74,251 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Mar 27, 2014
  • 53 Answers
SOURCE: No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Posted on Mar 14, 2008
  • 152 Answers
SOURCE: No power on LC32D50U Sharp
bobnyc, Is set under warranty? How old is it? Did it display a "perfect" picture yesterday, and not today. How is or was the AUDIO. Can you hear anything or nothing? Is the SMPS power supply board a "COMBO" or is the INVERTER supply located elsewhere? To where do the CCF tubes connect to get power? Tell me, do u have a good DMM, 100mhz Ocilloscope, Isolation transformer, and soldering iron/ solder wick???? If have some answer to some these ??? contact me @ louie12fix on fixya or at lmistyrel @aol.com PS: I highly recomend use of digital cam to take pic's before taking stuff apart. Could help when reassembling.
Posted on Mar 29, 2009
  • 9 Answers
SOURCE: power light flashes twice,then opc flashes once then power again
In all the time that you have had the tv have you applied 2 firmware updates that some of the tv's need to avoid other known issues with the lcd in the future. These firmware updates are for the main cpu PH1UU112 and the monitor MD1UA104. I don't know if this is the case for you but it worked for me. Call Sharp at 1-800-237-4277.
Posted on Oct 07, 2009
  • 8457 Answers
SOURCE: sharp lc-46d64u blinking codes. power blinks 3
Very common in Sharp,tries unplug,replug back in,tries again off/on couple times,still happen blinks than ur main video board it dead.
Posted on Nov 12, 2009
alpug
  • 1961 Answers
SOURCE: TV won't turn on
the first thing that you need to do is to open the back cover of your tv.Go to the power supply section it is separate board where the power cord is connected.Using a multitester,plug in the power cord and measure for the output supply.see if the 5vdc ,12vdc and 24vdc are present..if one of this output is missing,replace the power supply board But if the output voltage are complete,replace the inverter board,It is a board that supplies the high voltage to the backlights of your monitor/screen....You can also try to reset the system of your tv by pressing the the small switch mounted on the main board press it twice while the power is on...tnx and good luck!
please vote for my help!
Posted on Jun 04, 2010
TV turns on screen comes up just fine but won't stay on. What does the power button blinking twice and the OPC button blinking 3 times mean?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 04, 2016 | Televison & Video
Sharp aquos tv opc and power led flashing
http://electro-medical.blogspot.com/
Jun 01, 2016 | Sharp LC-52D62U 52 in. LCD HDTV
Is my tv main board bad
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jun 20, 2015 | Sharp LC Televison & Video
Model LC-465B57U flashing power light and opc light
Hi Tracy,
It appears your TV is not sequencing properly. By the order given in your instructions with the controller you are tuning, continue with a code until it satisfies .
Press setup- blinks twice. Enter TV manufacturer code- press enter. Light should flash once. Press on . After it works . Go through all the functions. Up- Down, loudness, channels,& on -off .
Fare .Well.
Dec 12, 2014 | Sharp Televison & Video
OPC and Power green lights blink twice, tv will not turn on.
follow this instruction and fix it. God bless you
    • 1
      Press the power button on the TV and not the remote control. It is possible the remote control's batteries are dead. If the TV does turn on, you know you need to replace the remote's batteries.
    • 2
      Disconnect the power cable from the TV, then insert it into a different electrical outlet. On occasion outlets are damaged, and do not provide a power current. If this is the case, changing the electrical outlet connection corrects the problem.
    • Sponsored Links
    • 3
      Switch the television's input to a different connection. It may be possible you have the wrong input selected, causing the TV to give off a black screen.
    • 4
      Connect a different source device (such as a DVD player or cable receiver) to the television. If the source equipment is damaged, you will not receive an image from the hardware. If the TV still does not display an image, there is an electrical shortage in the interior of the TV. To see if there is any way to fix this issue, you need to take it into a local TV repair shop.
Read more: http://www.ehow.com/how_7308433_flat-screen-tv-won_t-turn.html#ixzz2ZROWyhSB
Jul 18, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV won't show picture the power and OPC light blink twice together followed by three blinks from the OPC alone.
The main tv Tuner signal board have problems or it is dying or might be dead already.But sometimes this tv will still work and can be used,i have the same tv have the same problems it work for me all the times.By doing this process.Everytimes Power and OPC lights blinks.Just push the remote power switch again for tv to repower the tv power and OPC lights again,have go thought this process pushing power remote switch again have to do this like 3 or 4 times sometimes before the tv to work.Tries websites like Shopjimmy.com or Ebay.com to buy a whole new refurbish main tv Tuner signal board for the replacement.
Jul 30, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
Tv shutting off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Dec 02, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Oct 20, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC52E77UN 52 in TV Logo
146 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
