Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Has these appliances been re called
My LG profile refrigerator has gone out on me 2 time in one year.I need to know if this one has been recalled and the stove if you lean up or walki to close the stove comes on the knobs are pilling.I am with out a fridge I need help. The model number for the refrig is PSS26MSV/PSF26MGW this is GEProfile stainless double French doors
  • 958 Answers
SOURCE: lg french door fridge
do you have mechanical button switch that should close the light if you close the door?... they could be defective. try to look for these button switch that the doors presses as you close them. if they dont have, then they may be using a magnetic door switch which would be very hard to locate and trouble shoot.
Posted on Feb 13, 2008
MNTECH
  • 1543 Answers
SOURCE: door can't close on lg refrigerator
As you look straight at the white plastic square: Make sure the edge of the gasket is in place along the outer (in your case, left side) of the door. There is a metal spring near the white plastic square, and the end of that needs to be tucked into the groove of the door, not showing on the outside. Then, line up the white plastic square with the corresponding hole and use the palm of your hand to pop the gasket in, starting closer to the center of the door and working to the WP square area. (should only take about three hits.) Then, line up and snap on the long white plastic gasket retainer strip which runs from top to bottom along the inner edge of the gasket.
Posted on Mar 15, 2009
SOURCE: Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Posted on Apr 21, 2009
SOURCE: Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Posted on Apr 30, 2009
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
What is the width of Kenmore 253.57188600 refrigerator?
Hello Chris;
My name is Peter. I am a retired field service refrigeration technician.
First, The 253 model is an LG. Stay away from LG and Samsung refrigerators. 70% of my service calls were for either LG or Samsung. A common problem; LG would have compressor overload failures caused by the compressor. I would have to change both the overload and the compressor. This was a $650 - $900.00 repair. The Samsung has the best looking unit on the market, with the highest component failure rate. Their televisions are great, but appliances!
Ok, your dimensions.
1.) You need to take a tape measure and measure the space. You need 3/4" on the top and sides for proper air flow. You also require 2-1/2" in the back. Take this information to where you purchase a new unit.
2.) Consider going to a Sears Outlet Store (Scratch & Dent). You save a couple hundred dollars and have a one year warrantee.
3.) Consider a Habit Store for a used appliance.
Ok, What brand do I buy:
1.) If you can afford it: Kitchen Aid, Amanda or Hot Point (Fewest service calls).
2.) GE, Kenmore (Model number 110.---).
I hope I have helped;
Peter
Nov 30, 2015 | Kenmore Side by Side Refrigerator
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
GE profile refrigerator freezer fan noise
This is just one of a million reasons why they need recall initiatives in appliances like they do vehicles. So many of these manufacturing errors, which is what they are because they could be avoided if they were made right. We just had an issue with a fridgedaire dishwasher where the door spring had already broken, that should not happen after 4 years. Our USA products stink when it comes to good and basic manufacturing practices, still relying on "the good ole customer going to call for service" Nope, we just won't buy your USA products, which is sad, very sad.
May 30, 2012 | GE Refrigerators
GE French door profile freezer is not freezing
Call the service company back and make them fix the problem, period. If they said that would fix it then they just bought the repair no matter how much it costs.
Jul 03, 2017 | GE Profile Bottom-Freezer Refrigerator...
We purchased four new GE Profile appliances in August 2008. I contacted them in October 2009 to advise them that the shelving on the side-by-side of the fridge are to narrow, and the shelving and food...
unfortunately noone can help unless it is a recall and the only way for that to happen is for a bunch of people to complain about the same thing on the same refrigerator and that is a longshot my advice write ge and express ur feelings about the product and sometimes they try to fix the problem but u cant go back to where you bought it they cant help you hope this was helpful
Jan 24, 2010 | GE Profile PSW26P Stainless Steel Side by...
Not cooling
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Dec 17, 2009 | GE Profile PSC25PSWSS Stainless Steel...
LG Range LSB5611SS LHS element stays on
I have the same model and there is a recall on that model and others as well. The control panel will be changed for free. There is a site where you can check it out http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15538r-eng.php then contact LG
Sep 01, 2009 | LG LRE30451ST Electric Kitchen Range
GE Profile Refrigerator Ice/Water dispenser not working
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Apr 01, 2009 | GE PSS26SGR Stainless Steel Side by Side...
Refrigerator Lights Stayed on, Melted Plastic and Stopped Cooling
The control board relay switch for the light bulb stuck in the on position and needs to be replaced along with the light cover and housing.  There is also a replacement light harness that has a high limit switch to shut off the lights if this happens again.  LG knows about this problem and if you call LG customer service, they will grant a one time warranty extension to take care of this problem.
Jun 09, 2008 | LG LFC25760 French Door Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
