Question about Hasbro Furreal Friends Butterscotch Pony
Charger no way to charge it nothing works on it
Roomba 595 no lights - not charging
Just a idea but have you tried replacing the battery? Here is a link to a forum on this topic.
http://www.robotreviews.com/chat/viewtopic.php?t=2901
Dec 29, 2015 | iRobot Roomba 560 Robotic Vacuum
MH-25 is not charging the battery
Check the cords and make sure to disconnect and then reconnect the cords. Try the charger if nothing then try replacing the battery. If the battery is bad the charger will not work. If the battery is replaced and will not charge then replace the charger.
Mar 26, 2013 | Nikon MH-25 Charger NIKON
Napa charger #85-435 will not charge
He said his battery charger is not working, this has nothing to do with the car not starting or charging? So if anyone can recomend what he needs to do to get his battery charger working would be helpful to him.
Mar 01, 2013 | Cars & Trucks
Show nothing when charger is connected. please help me immediately . thanks in advance
This means that either your charger is not working or your phone's charge port.Try adjusting the charger point.Charge your phone through USB and see if its charging now.
Mar 24, 2011 | Cell Phones
Nothing happened when i charged it up
Hi, What you will need to do when mp3 player does not charge. First use another charger to test if it's the charger is working properly.
And secondly After testing for charger, and still it does not charge, that means the charging port on the mp3 player where the charger is been plugged in is not working properly. You will need to replace the charging port.
Hope it helps.....
Nov 29, 2010 | Audio Players & Recorders
Had new batteries and a service 6 months ago. Has now been left standing for a couple of months. I charged it up last night, but nothing. The charger appears to be working, lights working. Any ideas
Yes your batteries have dropped below 9 vlt each and they wont chage using your charger. Yuo must take a car battery charger and charge each battery up to at least 11vlts for your charger to charge! This ought to work if batteries have only been sitting a couple of mths . When using a car charger set charge at 6-10 amps for about 45mins to 1hr then hook up chair charger and you should be ok
Feb 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
My phone wont charge
check your charger first, if charger is ok then check the charging connector on the phone, clean it with a toothbrush and solvent cleaners.
Mar 27, 2008 | Samsung SGH-V200 Cellular Phone
Rokr e6
did that, both chargers work, fully charged both batteries. But when i plug the chargers into e6 it does not say charging battery and the battery symbol does not blink
Feb 16, 2008 | Motorola Mobility ROKR E6 Smartphone
Hasbro Furreal Friends Butterscotch Pony Logo
77 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
