Question about Nikon Coolpix S1 Digital Camera
Memory card is write protected
I've tryed two different cards , what can i do.  the camera is brand new
  • 4,889 Answers
You must be using an adapter?...
There's a white slide on the side. It says lock.
That may be the problem.
Unlock the card. Retry....
PLease comment befor you rate this thread..
Posted on Oct 31, 2007
I just opened a brand new SD card and tried to use it with my P850, but when I insert the memory card it says "Memory card is unusable. Insert new memory card." I've tried formatting and...
If you just purchased this camera, you can try phoning place of purchase or make a trip there. It sounds as if the software in camera may be messed up.
Sep 18, 2011 | Kodak EasyShare P850 Digital Camera
I have a V1003. It is saying memory card is protected (reset switch on memory card).
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card (which you said you've tried), or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
May 30, 2011 | Kodak EasyShare V1003 Digital Camera
Fuji finepix s700 camera error message protected card. After making sure sd card in unlocked. I still get this message. I had trouble getting out a sd card,i feel a piece of the sd card broke in the...
Take a small flash light and see if there is a part of a memory card in there, if there is cleaning it out would solve the problem. Also make sure you're putting the memory card in the right way. I've you've done that and it's still giving you problems try going into the menu's and formatting the memory card in the camera.
May 10, 2011 | Fuji FinePix S700 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Tried two different brand sd cards. c533 tries to
Try turning the camera off and then back on.Ensure that the memory card is the proper type for the camera. If the memory card is the proper type, try re- formatting the card using the Format option in the Delete sub-menu of the Playback Menu. If it will not format, it is probably corrupted. Replace the memory card
Jun 30, 2010 | Kodak EasyShare C533 Digital Camera
Error on formating new memory card in camera error says memory card is full brand new card i tried 2 in faact same error kodak c310
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Feb 08, 2010 | Kodak Easyshare C813 Digital Camera
From what I can see here, the card's size is too large that your camera couldn't support or handle. Maybe your camera is just limited to 1GB or 2GB. Try plugging 2GB card and see if it detects it. I had similar prob where I bought a 4GB card and it does exactly the same thing. I consulted the vendor, he said it only supports up to 2GB thus, it's a product limitation...well I'm stuck there hehe, can't be helped at all..
If you are certain that your camera can handle 4GB card or higher, try to plug the 4GB card into a card reader and see if it detets it. If it does, try to reformat the card and try it again to your camera.
Also, 1 possible thing is that your 4GB card is password protected. Was it plugged in to any other device? If it was, try to plug it back to the same device where it was connected and disable the password.
Onother thing is the brand. Some camera is brand sensitive when it comes to cards. You may need to try different brand as well.
Hope this helps. :-)
Jan 06, 2008 | Canon PowerShot A540 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
"Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Nikon Coolpix S1 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
