Question about Silicon Scientific Deluxe Infrared Quartz Heater
Have an E1 code
Goes right to E1
I just changed heating elements in my edenpure usa 1000 and now it keeps tripping my power strip ?
Check to make sure that the elements are weird in the right place.
See if there is any loose screws or metal on metal.
The elements might be bad
If wired wrong it may not be making a proper circuit.
Check the pcb boards to see if it is touching metal on the bottom side of board.
If you put a screw in the wrong spot it may be grounding something out.
Check all wires for bare spots
Oct 18, 2015 | EDENPURE USA1000 Infrared Heater
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
Dec 25, 2014 | Mr Heater Base Camp BaseCamp Little Buddy...
Heater pilot light will not stay lit
The thermocouple is either too far from the pilot flame or is bad.
Feb 26, 2014 | Garden Treasures Patio Heaters
No Flame
It could be dirty nozzle or dirty line
Unscrew every thing in the nozzle and control valve section and clean gas line and reinstall and try it
Nov 18, 2013 | Fire Sense 60803 Patio Heater
Eden pure beeps 3 times, and then it will not work
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Oct 09, 2013 | EDENPURE USA1000 Infrared Heater
Silicon Scientific Deluxe Infrared Quartz Heater Logo
155 people viewed this question
Top Silicon Scientific Patio Heaters Experts
deton8 von Splosion
Tom Chichester
Lawrence Oravetz
Are you a Silicon Scientific Patio Heater Expert? Answer questions, earn points and help others
