Question about Maytag MDB7749AWB Builtin Dishwasher
WILL NOT START
CLEAN LIGHT BLINKING BUT IT WILL NOT START
    Scholar:
  • 111 Answers
Does it blink 7 times pause then repeat if so either the heating element is open or wire burnt off bad thermistor very rare or a bad electronic control if it hasn't been removed the technical sheet is located in a plastic pouch on the panel below the door on inside you will have to remove the outer door panel to perform component checks
Posted on Apr 03, 2014
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Clean light blinking will not start
Count how many times it blinks before it pauses and repeats. If it's 7 times, then it is a very common problem, and you can find the solution by searching for "dishwaser clean light blinking 7 times".
Nov 03, 2014 | Kenmore Dishwashers
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher started up....didn't notice it quit running overnight...dishes seem only half clean. The "clean" green light is blinking. Tried opening and closing and then re-starting it. Can't get...
Greetings,
there is a temp related problem..this could be in the wash cycle not letting water get hot enough or a heater failure....remove your kickplate..there is a tech sheet..it explains how to reset this blinking light.....Bruce Denton
Jan 18, 2011 | Whirlpool Dishwashers
Blinking clean light
This blinking indicates a failure to properly heat the water, the link below will have instructions on how to reset the control so you can use the dishwasher and it will provide areas to look as to why it failed. Let me know if it was helpful.
Blinking Clean light
May 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
The dishwasher will not Start and the Clean Light keeps blinking
This blinking indicates the water did not heat up properly in the heated wash part of the cycle. I have put together some instructions on resetting the control so you can use the machine and some details on why it might have happened. Follow the link and if you have any trouble let me know.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Maytag MDB7749AWB Builtin Dishwasher Logo
113 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
