Question about Building Materials
What is the best paver sealer that gives u a wet look. Is water based sealer easier to use than acrylic using a garden sprayer
    Novelist:
  • 94 Answers
The most important "quality" of any sealer is the "% solids", especially for a longer lasting "wet look".
The % solids will be listed on the label (looks like the nutrition label on foods). We used to do extensive testing on many concrete sealers and coatings. A good penetrating sealer, applied in multiple coats, with a high % solids content, will be your best bet for what you desire.
PS: Most of the very well know names you see at Home Depot & Lowes are some of the lowest quality sealers on the market, and have very low % solids in them. One starts with the letter T (cough, cough).
Posted on Oct 30, 2014
  • 447 Answers
Try Home Depot, Lowe's. They have s variety of sealers. If they don't supply what your looking for, they will give you suggestions on where to go.
Posted on Sep 08, 2014
How to refinish pavers
It is possible to use a common garden sprayer made to spray liquid insecticides and fertilizers to spray both the water-based and petroleum based sealers available from home improvement or paint supply stores. Very effective and less labor intense than rollers or brushes. They are sold for about 20 dollars and can be cleaned afterwords for future use. Use care when pumping the handle and also if releasing the pressure as liquid may escape with air pressure release.
Jan 23, 2015 | Cars & Trucks
My tub is plastered into the wall with caulking. Recently, I have noticed that the caulking is dissapating and loosening up the tub. Fortunately, I have not see a change in my water flow. I want to
Unfortunately this is usually caused by a leak and the drywall is wet , and or the tub is sinking due to water damage to floor. If the drywall is solid then use a utility knife to remove old caulk, then after area is clean apply silicone caulk around the tub. apply neatly but with plenty enough to fill the void. I then spray a dish soap an water mixture on the calk then remove excess by pressing thumb down and sliding it long caulking. This presses it into the gap and also removes excess, which leaves you a neatly caulked tub.
Jan 23, 2015 | Pfister Tub and Shower Repair Kit SK0275
Do need to thin testors gloss acrylic paint
No- It's best to use testors thinner they sell for there acrylic paint
as a rule of thumb use the the same brand thinners and reducers as the paint your spraying, in this case testors.
Sep 18, 2014 | Tools & Hardware - Others
What's the best way to strip sealer off a stamped concrete patio?
Use a power washer on single jet on high power if u can get ahot water power washer all the better it will peel of easy
May 25, 2014 | Building Materials
Putting on acrylic Nails
OPI Crystal Nail File & Block Nail Buffer - Grab 2 or three different grits. Get a 4 sided buffer block as well.
  • 2Nail Prep & IBD Natural Nail Primer - This draws all the oils/moisture off your natural nail so the acrylic adheres.
  • 3Acrylic Nail Brush Set - Small ones are a little easier to control. Grab what you feel most comfortable with.
  • 4Monomer Acrylic Liquid - There is actually a primerless acrylic, I haven't tried it yet.
  • 5Acrylic Tips - There is a huge selection here, pick the ones that you like. I go for the semi opaque nude ones.
  • 6Acrylic Nail Powder - This matters. The cheaper powders turn yellow with age and with UV light exposure. This means tanning beds or natural sunlight. There is more 'lifting' when a cheaper powder is used.
  • 7Nail Lacquer - A base coat, a color, and a top coat.
  • To make life easier, you can pick up a pre-made kit like ASP Acrylic Nail Sculpture Kit that includes all of these supplies or save some money and just purchase a few things at a time. These tend to be a bit on the cheaper side (quality wise) but are great for quick acrylic nails. Or you can buy the professional kit like, IBD Professional Gel Kit
    Professional supplies can be bought online easily or at a store with a cosmetologists' license.
    • 1OPI Crystal Nail File & Block Nail Buffer - Grab 2 or three different grits. Get a 4 sided buffer block as well.
    A tutorial on acrylic nail application
    With supplies in hand...lets begin
    • 1Wash your hands.
    • 2Trim and file your nails short.
    • 3Use a soft/fine nail file to remove the shine off your nails - don't go too hard - this is just to scuff up the surface so everything can adhere to the nail surface.
    • 4Gently push back your cuticles - you may want to soak your nails in soapy warm water to make them softer and easier to push back.
    • 5Apply nail prep also called nail primer - it is a brush on solution that removes the moisture and oil from your natural nail. Allowing the acrylic to better adhere to your nail bed and not peel off a few days later.
    • 6Apply nail tips that fit each nail with adhesive. Super glue is generally provided in kits with the acrylic tips.
    • 7Clip the acrylic tip to your desired length and file the edges smooth. There ARE special cutters to cut acrylic tips, its probably best for you to pick one up, they are very cheap on ebay and will prevent you from bending or creating dents in the acrylic tips.
    • 8Reapply another coat of nail prep - this will again dry out the nail to allow for better adhesion
    Dip your brush in monomer; drag along the side of the container to remove excess liquid. Now drag a line through the acrylic powder and a ball will form. Watch this ball as the liquid soaks up into the powder. Once a jelly like substance has formed, place that on the line where the acrylic tip and natural nail meet. This will deposit the thickest coat and now you can push the acrylic up to the cuticle and nail tip. Smooth it as best you can, use light delicate strokes. Multiple layers can be applied to achieve smoothness. Also note - this step doesn't have to be perfect as we will file the acrylic down to shape.
  • 10Acrylic dries fairly quickly. Once you have applied all the desired coats, file down the top of the nail smooth. Use a coarser grit to start and then work your way down to a very fine grit. This remove scratches in the acrylic and make the nail appear smooth once polish is applied.
  • sorry it was so long.hope that helps
    Jul 03, 2013 | Health & Beauty
    Moultrie 25 gal spot sprayer for water sealer treatment
    Yes, I've used pumpup hand sprayers to apply sealers. Is the sealer water-based? If not, cleaning up the sprayer afterwards could be a chore!
    Mar 01, 2010 | Moultrie 25 Gal. Spot Sprayer
    Bissell quicksteamer 1770
    The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix. My model is different than yours, but many models are similar.
    Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
    Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
    When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
    Now do the same for the other red water sprayer.
    I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
    There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
    As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
    Feb 22, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
    I have a Bissell model 1694 It is not pumping water
    Jan 20, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
    My Bissell Proheat 8910 does not spray water onto carpet.
    Jan 14, 2009 | Bissell 8910 ProHeat Clear View Upright...
    Building Materials Logo
    329 people viewed this question
    Top Building Materials Experts
    Terry Smith
    Level 1 Expert
    Tom Chichester
    ray gallant
    Are you a Building Material Expert? Answer questions, earn points and help others
