Question about Vehicle Parts & Accessories
Sola larm fob 2 button type how do i use it where can i download a user manual
2 Suggested Answers
SOURCE: i have a sola-larm 835T, the alarm is not
You need to disconnect Battery. On reconnecting, you will hear a "chirp" from the Alarm System. Within 2-3 seconds, press the button on your transmitter, and you should hear the Alarm respond correctly.
Posted on Mar 04, 2011
Binaton solas 1520 only rings 3 times before answer machine kicks in
You should check user's manual. If don't have one, download it from here
Download manual
Oct 22, 2015 | Binatone Lands Phones
How can I reprogram my Jaguar X Type Key so I can unlock and lock my doors?
if your just programming the fob to the module and it has not been replaced and your just needing a manual reset,then follow the folowing procedure:
1 Insert key into ignition
2 Turn key to 'I"
3 Turn key "II" and back to 'I' quickly 4 times
4 Alarm system will chime once when key is back to 'I' for the
fourth time
5 Remove key from ignition
6 Press any button on each key fob and alarm system will chime
for each fob if it has been programmed correctly
7 Press unlock/lock/trunk etc to make sure everything works
Dec 12, 2011 | 2003 Jaguar X-Type
Crimestopper SP501 car alarm/remote starter will not respond. The 2 way one doesn't work, the sidekick does.
You need to program your crimestopper sp-501 key fobs, you need to program both the 2-way and the 1-way key fobs, during the same key fob program session. First find your valet button/switch, when you have found it, turn your ignition on and press the valet button four times, if you have a toggle type switch for a valet switch, toggle it up and down four times, when its in remote key fob program mode, it will honk your horn 4-times followed by 4-parking light flashes. Once your have done this press the lock button on the 2-way key fob, horn will honk and the 2-way will sing a little song to confirm programed, then press the lock button on the 1-way key fob the horn honk will be your confirm programed. turn ignition off this will exit you from program mode. then shut all doors and test key fobs for operation functions....hope this helps you out
Dec 03, 2011 | 2006 Hyundai Sonata
I want to change the battery on my jaguar x type key fob. How is this facilitated please?
SPLIT THE KEY FOB INTO 2 PIECES BY USING SREW DRIVER THEN THE PART WITH THE BUTTONS UNDERNEATH UNCLIP AND THEN UNSREW THE CIRCUIT AND CHAGE THE BATTERY SIZE 2032
Apr 17, 2010 | 2004 Jaguar X-Type
I have a sola-larm 835T, the alarm is not recognising or responding to the signal from the key fob transmitter.The alarm is armed and i cannot cancel the immobiliser.New batteries are fitted. Any idea's...
Aug 09, 2009 | Vehicle Parts & Accessories
On my saab vector ignition key functions
I have a Saab 93 Vector and although my key does not have that function my manual says the following; 'Press once - Turns on exterior and cabin lighting, for 30 sec, or turns off lighting. Deactivates panic alarm. Hold and press for more than 2 sec - Cars with car alarm: panic alarm (activates alarm manually).
There is another section that says the button turns off lights and larm when activated and the car remains locked. The panic alarm can only be activated when the car is stationary and it will be silenced when the car is driven away.
Hope that makes sense. Enjoy your Saab 93 - I know I do every day.
Tony
Mar 31, 2009 | 2004 Saab 9-3
Automatic Seat Positions Adjustment
Mine's a 2004. Assuming your's works on the same mechanics----- Set the seat, radio, mirrors, etc to where to want them then push the button on the arm rest on the door until it beeps. Obviously, setting 1 is for whoever uses key fob 1 and 2 is for key fob 2.
Jul 26, 2008 | 2002 GMC Envoy
Vehicle Parts & Accessories Logo
181 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
