Question about Peavey Audio Players & Recorders
How do you remove the knobs on a nashville 1000
They are creating stactic
    Problem Solver:
  • 13 Answers
General knob removal is look at the knob all the way around and see if there is a hole, if there is, its got a set screw in it to hold it on the shaft. You will have to try to peek in there to see if takes a straight blade screwdriver or an allen key. If there is no hole, then the knob is just slid on the shaft, so if you can pull straight off, then use a spoon on either side as a lever to get it started.
Posted on Mar 30, 2014
Year and approx. worth of my Les Paul Custom. Good condition. Original except for tone/volume knobs. Black with gold h/ware. Serial #00122622. Thanks
Your guitar was made at the Gibson Nashville Plant, TN, USA on January 12th, 2002.
2002 values vary widely with sub-model, finish and condition. According to Reverb.com it would sell for $US1000 - 1600.
Aug 21, 2017 | Music
Is there a repair shop in the Nashville area?
hi if u ring this number they might help u +1 (310) 328-8866 cheers
Sep 28, 2015 | Shoprider Scootie
Nakamichi 1000 Tri-Tracer.When switch the deck on right channel has noise and doesn`t play.After 10-15 min it appears and sounds ok.Condenser on right channel just gone?
It can be that or a bad FET or some other part of the circuit. To get it fixed right I would consult Tom at the below location as he is a Nak guy.
Tom Brucker
Hi Tech Service
2934 Nolensville Pk.
Nashville, TN 37211
615-331-9241
hitech@BIRCH.net
Oct 18, 2013 | Audio Players & Recorders
Can you give me the radio code for blaupunkt
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Jul 03, 2011 | Blaupunkt Nashville DAB35 CD Player
I used my Behringer 802 mixer for the first time lastnight and when i woke up this morning and tried to record,the sound was very distant and hardly audible.I tried to raise the volume by turning the main...
What are you recording from? If using a condenser mic and you fail to turn on the Phantom power, symptoms such as you describe would occur. You don't include enough information about your setup to allow us to help.
Jun 27, 2011 | Behringer XENYX 1002B Mixer
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Is there anybody to help me? It's urgent please...
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Good Luck!
Mar 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need to find instructions to change combination on Kaba L 1000 keyless lock.
REMOVE THE KEY.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Good Luck!
Feb 24, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Reset combination to keyless door lock
REMOVE THE KEY.
Dec 09, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Need to know how to reprogram the code on a Simplex Kaba IIco Unican 1000 keyless lock
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Dec 05, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
What is the zip code at Nashville?
dunno what do u need it for.. but here u go
Nashville's zip code: 37201–37250
thanks to wikipedia :)
http://en.wikipedia.org/wiki/Nashville,_Tennessee
Feb 09, 2010 | Nokia 1100
48 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
