Question about Oster Black Large Digital Countertop Convection Oven Tssttvmndg001
Where can I get an interior light bulb replacement
Where can I get the interior light bulb replacement ?? I wrote to oster and they send me to their service centers but closest one is 4 hours away. The bulb have the following inscription: 120v 15w 3*C walk long
  • Hugo Zapata
    Hugo Zapata Mar 27, 2014
    Correction
  • Hugo Zapata
    120v 15w 300*C walk long
Oster 6058 Toaster Oven heating elements are not working properly. Can parts be replaced?
You will be able to locate authorized parts and service centers by visiting http://www.oster.com
Regards.
Jun 17, 2011 | Oster 6058 Toaster Oven with Convection...
Our Oster toaster-oven (Model 6232) takes a long time to heat up. The heating elements are no longer bright red but rather heat up to a "dull" red. Might the problem be related to the thermostat...
You might try going to oster.com. After putting in your country, at the top of the page click on Customer Service and fill in where you live and you will get a list of service centers that you could check with. If you know what needs replaced and can do it yourself, then use this address to get parts. This will give you a list of sites that sell parts. Maybe just get both parts to see which it is.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Mar 17, 2011 | Oster 6232 / 6233 1500 Watts Toaster Oven...
I need to purchase a replacement for my toaster over #6233 - I need a new Baking Pan & Broiling Tray. Mine is very soiled and will not clean
FYI Oster Toaster Oven: about 18 months ago after careful consideration we purchased a counter top toaster oven for the RV from WalMart. I have a 20+ year old Oster Kitchen Center and found easy access to repair parts a couple of years ago, very pleased.
Last trip out in the RV the timer knob stripped out after what I would describe as a couple of months of light use. Google'd the model in search of a replacement knob only to find many others had "been there, done that". The model is obsolete and no service parts are available.
The Oster customer service rep seemed finished at this point and asked if there was anything else she could do for me. I asked what I, a long time Oster customer, should do with the useless oven. After repeating the question rephrased several different ways she put me on hold.
She returned several minutes later to inform me that as a "one time" courtesy Oster would replace our out of warranty oven with a current model. The replacement unit would have no warranty or support from Oster.
She supplied the model number and gave us an Order #. Looking up the model number and checking reviews I have very low expectations for the replacement. Most comment as to the poor quality and reliability of this current model.
A perfect example of a manufacturer who once produced a quality produce but now sells cheap imported disposable products.
YMMV
Nov 07, 2010 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Broken timer knob
I had the same problem where the time knob broke. I filled in a claim form on the Oster Website and they answered within 3 days saying the timer knob was discontinued and no longer available. They proposed to replace the whole toaster-oven with another model 6073-33 which I received last week. I've to say that their customer service was amazing.
May 04, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
OSTER TOASTER OVEN --- TIMER TWIST KNOB BROKE
you can get on amazon for sure. take a look here Thanksgiving essentials from the Oster brand. p.s. take a look on seller reviews. I hope this was helpful. cheers
Jan 19, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
The knob on the bottom dial of the toaster oven has cracked and fallen off. Can i get a replacement knob so that I cAn turn the toaster oven on I need all three knobs (temp, function & timer) for my Euro...
You *can* order parts from the manufacturer directly, but good luck with that. The first time I called, and mind you their 1-800 # is a quagmire of numeric menu selections before you ever get to talk to someone, they said they would be happy to send me one but they were out/backordered and that I should call back in 2 weeks. Instead of putting me on some kind of list and sending me one when they got more...Grrr! Then I tried calling back and made it, again, through the menu maze only to find out they are in Eastern time. Super frustrating!
But I also discovered that the flat head screwdriver is the best temporary solution until I can get my hands on a replacement knob!
Dec 06, 2008 | Oster 6071 Toaster Oven with Convection...
My toaster keeps beeping and comes up with an error message can you help
I just called Oster Service and the said to plug in the unit, hold the start button for 10 seconds and unplug the unit. My oven reset before I was able to try this, so let me know if this works for you.
Dec 08, 2007 | Oster 6235 Toaster Oven with Convection...
Oster microwave/grill
ha, had the same problem, just call the oster custumer service and they can send you a new one for $5
1-800-968-9853
Oct 06, 2007 | Oster 4877 / 4878 / 6209 Toaster Oven with...
Oster Black Large Digital Countertop Convection Oven Tssttvmndg001 Logo
35 people viewed this question
Top Oster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
ray gallant
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
