Question about Garmin Nuvi 660 GPS Receiver
My Garmin is stuck in simulation mode at one of my last locations
Somehow the "current location" is set at one of the last places that I went and now everything that I put in is simulated and starts at that location instead of where I am.
I have tried changed just about everything that i can think of.
All garmin nuvi users reset device small button on bottom then plug into computer using usb cable back up the nuvi folder in my computer,just in case, then run virus check on device`s nuvi folder when finished unplug safely , hopefully should be back to normal i have down this with 2 nuvi`s with keyboard problems and it has worked both times hope works for you regards brettjohns1350@bigpond.com
Posted on Jun 15, 2009
It won't pick up the satellite signal so its stuck at it last place searching for a satellite feed.
Should not take more than that unless you have installed a new set of maps in a new location. Call Garmin to confirm. Try installing latest firmware for unit to see if that resolves the issue.
If that does not do the trick then maybe...................................
Oct 15, 2015 | Garmin Nuvi 50Lm - Gps Receiver
GPS System isn't working
could be a simulation settings was still ON mode, thats why it will not do tracking your way point.
Aug 08, 2008 | Dodge Nitro Cars & Trucks
It will not talk r give the right directions. Everytime i enter my location it ask if i want to simulate route. If u hit no it turns off. If u hit yes it starts telling u to turn and there isnt one and...
Either you are in GPS simulator mode or you are unable to receive satellite signals. go into your tools menu Tools > Settings > System > "check if GPS simulator is activated". De activate if it is and your unit should work fine, if this dosent work try giving the unit an update using Garmins WebUpdater software it can be obtained from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 13, 2011 | Garmin nuviĀ® 200 Car GPS Receiver
I have a Garmin Nuvi 205W and have saved a number of places as favourites. However, when I want to share the location with friends by giving them the map coordinates of these places I cannot find how to...
To view the coordinates of a saved location on your nuvi
  1. Touch Tools (wrench icon)
  2. Touch Settings
  3. Touch System
  4. Turn ON the GPS Simulator
  5. Touch OK
  6. Hold Back to return to the main menu
  7. Touch Where To?
  8. Touch Favorites
  9. Select a favorite location
  10. Touch Show Map
  11. Touch Set Location
  12. Hold Back to return to the main menu
  13. Touch Tools1
  14. Select Where Am I
Here you will see the coordinates for the saved location.
1. For nuvi 200 series units that do not have the Where Am I feature, skip the above steps 13-14. The coordinates can be found by pressing the vehicle icon on the View Map page.
Instructions on Backing up and restoring Favourites can be found at
http://www.garmin.com/garmin/cms/cache/offonce/us/support/searchsupport;jsessionid=72CF55C22FEF1BA5AA08FFCAC89B9E59
Aug 12, 2010 | Garmin nuvi 205W GPS Receiver
I have a Lowrance iway 500c. When I power it up, it does not find my current location. It comes up with a location in Florida where my father-in-law was in Florida with the unit earlier this year. . When I...
When was the last time you went into the your settings and update your software or configured the unit? On cloudy days you can't do this. On a bright sunny day go outside and try this.
Dec 14, 2009 | Lowrance Iway 500c GPS Receiver
Electrical problems
Well, congrats on a great vehicle!
Suggest that you get a cheap volt meter at Harbor Freight (about 3 bucks) and then check the current draw at the battery (with everything off, pull the positive cable and place the voltmeter (set on DC Current/Amps) between the cable and the battery.
What current level does it show? More than about 200MA is a problem (you need to be sure that the internal door lights are off!!)
You can set the meter on the hood so that you can see it from inside the vehicle... Then, with everything off, and the voltmeter set as described above, pull a fuse and look at the meter. Repeat the "fuse pulling" exercise until the meter reads about 0 MA draw. That is the circuit that is causing the problem.... NOW you can troubleshoot a simple item or set of items.... until the problem is fixed.
To keep the battery charged overnite, keep the fuse pulled until the problem is fixed.
Oct 08, 2009 | 1995 Ford Ranger Supercab
Can I have the fuse diagram, too?! Thanks!
I found the diagram on the Honda website. With it I found out that the #19 fuse is dedicated to these issues. Somehow, a 7.5A fuse was in this spot. It is supposed to be a 20A. Everything works fine now that the 20A is in place.
Sep 22, 2009 | 1994 Honda Civic
My Garmin is stuck on my last destination.
Your Garmin's Home Location has been changed.
Solution: You must reset your Home Location.
Go to Main Menu.
Select: Where to?
Select: My Locations.
Select: Set Home.
(Message: A Home Location Already Exists. Do you want to change this location?)
A. If you are at your home location, select: Yes, use my current location.
B. If you are NOT at your home location, select: Yes, enter my Address. Enter your Home address.
Press "Save".
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
Waypoint selection uses last location instead of current location
Backup all data and reset the unit. Hope this helps...
Jan 14, 2009 | Garmin Rino 120 2-Way Radio
Garmin Nuvi 660 GPS Receiver Logo
972 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
