Rinnai r85 exterior propane tankless water heater makes knocking/clicking noise. seems it tries to start with clicking noise then no fire in burners then cycles again. no error message. have two rinnia side by side other works without issue. not sure if safe to sssume gas pressure is fine. took out fan,air cleaned it,checked vent no issues. air cleaned burners,no build up where pretty clean from last cleaning 6 months ago. coils cleaned. cleaned spark and flaming rod. pieces all put back same issues. not sure how to troubleshoot to ensure gas us going in system. also to ensure spark rod is working. win d ow into burner is pitch black just cycling of clicking noise.
On start up the clicking noise is normal as well as knocking noise ....one important item with fan , if the fan was removed cleaned and then reinstalled with power to unit could have ruined the fan and it will have to be replaced..... Cant tell you why is wasn't firing before with no codes...other than flow sensor not working( most likey stopped with sand fragments or trash) the flow sensor detects hot water demand and ignites heater and if clogged it will not light up but doesn't give error code and the water running through hot side will be cold..... flow sensor is a turbine that detects water movement and lets heater light..... may want to get serviceman to check this out and clean turbine.... hope this helps...
Posted on May 31, 2014
  • Mike Edwards Sep 04, 2014
    Everything David said is right, but you may have a regulator problem. if it is Propane or Natural Gas. They both do not enter change. I have seen some that bought wrong heater's and If you put to much pressure on the Natural Gas it will lock up hopefully. But yes check on line to work with the Dealer.
Rinnai R85 starts to warm then stops and blinks 61??
I went to the Rinnai website and this is what I found for error code 61.
Error Code 61 Problem: Fan failure
Solution: Measure the resistance on the fan motor, check the damaged or loose wiring and connections. Make sure that the fan spins freely.
Sounds like either your fan is broken or something is keeping it from spinning freely.
Hope this helps.
Gary
Feb 24, 2015 | Rinnai R85ePLUS Tankless Water Heater
R85 tankless water heater
Probably frozen. Let it thaw out and see if it works. You may want to think about wrapping the pipes with heat tape because of those low tempertures they could break especially if the unit is outside.
Good luck,
Marty
Jan 07, 2014 | Rinnai Digital Remote Water Heater Control...
RINNAI R94LS CONVERT TO NATURAL FROM PROPANE
The electric water heaters have replaced the traditional of water heating. The advanced features and the latest technologies of water heater have made it so easy for everyone. Find the best electric water heater on the market today. Read electric water heater reviews and comments from experts. Almost each product is manually reviewed and tested.
Electric Water Heater List Reviews waterheaterlist com
Jan 28, 2013 | Rinnai R94LSi Tankless Water Heater...
Exterior mounted Rinnai tankless water heater not
check to see if you have a blocked line on the hot water side
Jan 08, 2010 | Rinnai Webstone The isolator EXP tankless...
Our tankless water heater is not turning on, but
blockage at pilot ,gas valve faulty ,if you have a changeover valve fault could be there
Oct 07, 2009 | Rinnai Webstone The isolator EXP tankless...
The Pilot burner flame is large & yellow
the pilot is getting too much air and is an indicaiot of dirty or air/ fuel ratio imbalance. The pilot is wimpy and the thermocoupler has alot to do with the gas . Make sure your thermocoupler is on the tip of the flame. You may end up replacing it. because it is showing signs of eminnt failure. When it fals your curners won't fire up. Good luck.
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
The burner lights up when it shouldn't
your thermostat is bad and needs to be changed but I am not sure if it is tied in with the circuit board or not, on the rinnai units it is and you would have to change the circuit board
Jun 07, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Rinnai Tankless Water Heater
Question, is there any other equipment that uses propane? You indicate that the problem started after a delivery of propane after running out. If so, I suspect a blockage in either the gas train or the rinnai itself. If tou have the temperature control that regulates the water temperature, you can recall error codes to pinpoint the issue. They are optional equipment so if you can wire one in or ask your propane gas supplier if their service department has one, it will aide in the diagnosis.
Nov 22, 2007 | Heating & Cooling
Heating & Cooling Logo
122 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
