Fisher and Paykel GWL15 doesn't work, beeping continuously
I have a Fisher Paykel GWL15 which stopped working mid cycle (still has water and will not drain). It is beeping continuously and will not enter diagnostic mode by following instructions on the service summary sheet. LEDs # 3, 4, and 8 are lit which would seem to indicate error code #49 (faulty hot/cold water valve). I replaced hot/cold water valve with a new part I had on hand, but cannot get the washer to work - it still beeps continuously. What could be going on here? Faulty control panel? Any help or advice is greatly appreciated.
  • 28 Answers
SOURCE: my fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Posted on Jul 03, 2008
SOURCE: Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Posted on Jan 13, 2009
stephanos18
  • 144 Answers
SOURCE: Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Posted on Mar 25, 2009
sonicboomele
  • 1557 Answers
SOURCE: Error Code 49 Fisher and Paykel Washing Machine
the code error (49) is telling you that the inlet valve is not working make sure the hoses are not blocked. if you have fitted the valve and is still not working then i would try using the unit on cold if it still does not work then there must be a short in the p.c.b control board.
hope this helps a little more
Posted on Jul 12, 2010
  • 1583 Answers
SOURCE: my fisher and paykel ecosmart gwl15 won't do a hot
There are several possible causes. To track down the problem, first shut off the water supply valve feeding the washing machine, then remove the hot water hose from the machine and direct it into a bucket. Turn on the water supply valve. Does water come out? Is it hot? If you only get cold water, then you need to insulate the pipe between the water heater and the supply valve so you get hot water faster (assuming the water heater is working!)
If you have a supply of hot water, then check the inlet screen where the hose connects to the washing machine. Perhaps it is clogged with lime or sediment. If it is clear, then you have a fault in the hot water solenoid valve or water temperature selector switch.
Posted on Dec 05, 2010
GWL15 fisher and paykel stops mid spin
If the only light on was the spin when it was beeping,
That is fault code 1
1. (00000001) Motor Control Module Fault
The Motor Control Module has encountered an error when writing to an EEPROM address.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Mar 18, 2013 | Fisher Paykel EcoSmart GWL15
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 overfills and will not advance
Is it filling so it is flooding your floor? Could be that too many suds are in the pressure switch tube ( are you using "he" soap? ) or the pressure switch is not registering the water level. Note the lights illuminated when it beeps and call F/P.
Jul 03, 2009 | Fisher Paykel EcoSmart GWL15
Machine stops and will not move to next cycle--spin
Sounds like it it not recognizing that the lid is closed, could be a bad lid switch.
Apr 14, 2009 | Fisher and Paykel Fisher & Paykel Washer
Stops mid cycle
It may be a out of balance alarm during a spin cycle. Re-balance the clothes and hit start.
Jun 12, 2008 | Fisher Paykel EcoSmart GWL15
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
