Question about Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet
My proscan plt9045k is not accetping my google password
Proscan plt9045k
I don't remember my password to my proscan plt8088 tablet
Sadly there is nothing we can do , as we never had your password and you didn't write it down either
Mar 22, 2016 | Tablets & eReaders
I don't know my password to my tablet (child changed it).
Hi Lucy!
Here is a link to the Proscan Manual.
All of the info you need is in there.
Item PLT7044K ProScan
Best of Luck,
JP
Jun 30, 2015 | Proscan 7-Inch Android Internet Tablet,...
I forget my password to get into my proscan 7" tablet PLT7100G(DG)
If it's linked to a Google account. It should give a option to login to unlock the device.
Dec 02, 2014 | Tablets & eReaders
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Jul 12, 2014 | Proscan 7-Inch Android Internet Tablet,...
How do i unlock a proscan plt8816k if i dont remeber the email and password?
Your problem doesn't make sense. You cannot try the password too often. Try a factory/hard reset.
Google search "reset android tablet"
May 10, 2014 | Proscan Recertified - PLT7035 4GB NAND...
How to unlock tablet proscan PLT7223G
Download the firmware update PRO_PLT7223G_FIRMWARE.ZIP
Download the RockusbDrivers from https://docs.google.com/file/d/0B_keThrKc71iYkZXMHNxZWdVT0U/edit
Save these files to a new folder on your desktop.
Unzip the FIRMWARE file and follow the instructions. When you need the tablet drivers, manually install the drivers from the RockUSBDrivers files in the new folder you created.
Jul 19, 2013 | Tablets & eReaders
Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet Logo
50 people viewed this question
Top Proscan Tablets & eReaders Experts
tosin_christ
David Payne
David Payne
EE Eddie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
