Question about Hobart Vintage Coffee Grinder Model 3241 - Excellent
Need glass for the top of a Hobart 3330
I am missing the glass is missing from a hobart coffee grinder, Mod. 3330 Spec. 3847 Phase 1. Is there any place I can get replacements for it?
ricardok45
  • 135 Answers
SOURCE: Hobart A-200 serial # ?
Hi. Your mixer was manufactured in 1967. If you plan on keeping it, take the outer cover off, gently remove the two metal dust caps with a small screwdriver and look into each opening with a good flashlight to determine the quality and amount of grease in the trans. case.
Ideally the grease should almost fill the space with no oil visible. If you need to look further, I suggest that you open up the transmission cover, to determine the condition of the grease that lubricates the transmission. If you find that oil is seperating from the grease. you would do well to remove all of the oil and old grease and replace it with either Shell Darina EP-2, or Chevron FM ALC EP-2 grease. It's a messy job, but it will add years of life to your mixer.
Check the planetary seal, remove, clean and regrease the planetary gearing. With a mixer of this age, you never know if it has ever been serviced since it's manufacture or not. The grease must totaly encapsulate the trans. gears. As the grease breaks down it's level lowers and it leaves some of the upper gears without lubrication, and will result in preventable wear.
Good luck! If you found this solution helpful, please rate it. ricardok45
Posted on Feb 26, 2009
  • 3600 Answers
SOURCE: electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Posted on Jul 24, 2009
ginko
  • 19396 Answers
SOURCE: NEED SOURCE FOR HOBART DISHWASHER PARTS
Try the link below:
Appliance Parts -Research, Repair & Replace.
Posted on Sep 10, 2009
tooltech75
  • 80 Answers
SOURCE: wiring diagram for a Hobart D340 40qt mixer
i read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
Posted on Oct 08, 2009
ginko
  • 19396 Answers
SOURCE: My mother needs a replacement bowl for a Model 4C Hobart Mixer
Hi.
The Hobart/Kitchenaid model 4C Stand Mixer was produced between 1961 and 1977.
This unit is now a vintage piece chased by collector. Parts dealers do not sell parts anymore for such an old model.
The parts must be purchased on the second hand and vintage market, best source is Ebay. Put 4c mixer or kitchenaid 4c to find parts.
The bowl is easy to find, it is part 4162158, regular retail price for replacement is $44. buy the glass one on Ebay, that will be the original one mounted on first models.
Here Ebay list.
Vintage KitchenAid 4c Glass Mixing Bowl Excel Cond!
VINTAGE KITCHENAID 4C MIXER WIRE WHISK ONLY
KitchenAid Mixer md 4C Complete with Bowl White
KITCHENAID MIXER 4.5QT S.S. BOWL FTIS MODEL 4C 4162158
Here also a forum where you can contact more Kitchenaid vintage appliances owners or collectors.
The dough tool is not even easy to find on Ebay. Try contacting Kitchenaid and see if they can give you a compatible part.
If they have the original one (unlikely) , then do not be surprised if part price is over $30.
If you find a 4c with tools for spares on Ebay , buy it, and resell the parts you do not need. The whole mixer with bowl and one tool is worth over $50.
The original owners manual can also be purchased from Kitchenaid/hobart
Regards.
KitchenAid Customer Service
Posted on Nov 13, 2009
I am looking for a wiring diagram for Hobart 4822 grinder
Ask direct. not available online.
Electrical Installation; Electrical Connection - Hobart 4822 Installation ...
https://www.manualslib.com > ... > 4822 > Installation and operation manual
  1. Cached
Hobart 4822 Manual Online: Electrical Installation, Electrical Connection. The Electrical Installation Of The Chopper Must Conform To The Local Electricity...
[PDF]4822 MEAT CHOPPER 4822 MEA T CHOPPER - Hobart
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F7515.pdf
  1. Cached
  2. Similar
Page 1 of 2. 4822. MEAT CHOPPER. 701 S Ridge Avenue, Troy, OH 45374. 1-888-4HOBART ... CORD AND PLUG: A 6 foot, flexible 3 wire cord is furnished with the ... CAPACITY: 4822 will grind 16 lbs. per minute, first cutting through a 1?8" ...
[PDF]CATALOG OF REPLACEMENT PARTS
www.hobart.co.kr/data_file/4822Aug04.pdf
  1. Similar
4822 CHOPPER REPLACEMENT PARTS. F-43093 (August 2004). © HOBART. Table of Contents. 3. ELECTRICAL UNIT. 5. #22 CHOPPER ATTACHMENT ... wiring diagram for Hobart 4822 grinder Google Search
Feb 08, 2017 | Hobart Food Mixers
Meat grinder does not work but it makes a humming sound
First check- is unit single phase? Check for bad capacitor(s).
- is unit three phase? Check for missing leg(s) or
bad wiring conections.
Next check motor windings and for shorts also if it is mechinal binding up.
If motor is good , check for problems in the drive train.
Sep 03, 2014 | Hobart Food Mixers
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
Were can i find hobart coffee grider
HOBART?
That is an old vintage grinder you might find one on the internet.
What is the problem you mention and what kind of grinder?
Jan 13, 2011 | Coffee Makers & Espresso Machines
Electrical connection of hobart h600
Jul 24, 2009 | Hobart H600 Stand Mixer
Hobart A200
Yes A-200 are number 12 I would find a hobart grinder they will have a big H in the casting on the neck get one with a stainless pan and stomper to push product down the throat. If you wait on Ebay and put it on your watch list they do come along. look for no rust. Make sure it has the big H in the casting. the other after market ones seem to not last long like the metal wears on the worm and hub to fast. also you always know where to get a piece if you need it if its a Hobart. not so with the forign jobs.
Dec 29, 2008 | Hobart A200 Stand Mixer
Parts and Grind Selection
The current Kitchenaid A9 burr grinder glass jar is interchangable with the original Hobart/Kitchenaid A9 glass jar; therefor, the gasket should also interchange - contact Kitchenaid customer service to order a gasket.
Setting the grind is accomplished by grasping the body of the ginder in one hand and the grind-selector ring (collar that the jar screws into) in the other. Hold the base tight and turn the selector ring clockwise for a finer grind, counterclockwise for coarser. Be careful not to completely unscrew the selector ring; if you are not sure how much adjustment is left, screw it all the way clockwise until it stops (finest grind); then, back it off, up to one full turn to make the grind coarser.
The selector ring has the words coarse, medium and fine cast into it; these are rough postition markers. There is a triangle cast into the body of the grinder, just above the brand name, that can be used to diral in a preferred level of grind. I use a medium-coarse grind for drip coffee makers; to do likewise, position the selector ring so that the triangle is pointing midway between the words coarse and medium.
Dec 21, 2008 | KitchenAid A-9 Electric Burr Grinder
Grinder attachment
Cindy,if it has a screw take it out,grab a flathead screwdriver and work your way around the cap.Some mixers have been painted or just the gunk over the years make the cap hard to pull off.The push button i have never seen on a hobart mixer near the hub.Give me the serial and spec number.
Nov 12, 2008 | Hobart A200 Stand Mixer
Hobart Vintage Coffee Grinder Model 3241 - Excellent Logo
56 people viewed this question
Top Hobart Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Hobart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
