Home | Bissell | 9500 ProHeat 2X CleanShot Upright Deep Cle... | Bissell 2x wont **** up ...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Problem for Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner,...
Bissell 2x wont **** up the dirty water
By deborahfogel on Jun 15, 2009
my bissell upright 2x wont **** up dirty water any more. I cleaned everything but it didnt work.
Sponsored Links
Best Solution
posted on Jun 15, 2009
Helpful)
Cbbrink
Rank: Wiz
Rating: 90%, 24 votes
take the tank off and turn the unit on and see of there is section where the tank would sit. If so then the tank is not seated correctly, if not it is plugged with something.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Sep 12, 2009
Very Helpful)
gon2oahu
Rank: Master
Rating: 88%, 13 votes
My machine would not **** up the dirty water either. I tried everything, read the "troubleshotting" section in the manual and nothing worked. Then I discovered there is a little FILTER that is not mentioned anywhere and is hard to see. It was clogged with dog hair. It is in one of the two removable sections on the top of the machine. It is NOT in the bladder section but the section with the dial to switch from floor to tool. It is red and about 1 inch long. There is a little door on it that you flip open (it actually looks like you can remove it). Flip the little door open and you will probably find a bunch of gunk. Remove it and the machine should work perfectly. Mine now does! Good luck.
Was this helpful?
Yes
No
Solution #3
posted on Jun 23, 2009
Very Helpful)
weemom
Rank: Apprentice
Rating: 100%, 1 votes
I've been working on solving this problem on my Bissell all day and at last I think I may have a solution...there's a little red rectangular shaped plastic filter in the top part that has the handle (it's the only red plastic thing you'll see in there). Mine was packed with lint and covered completely. I removed all of the lint and the water should now be able to be suctioned through. I haven't tried it yet, but I'll let you know if it did work. It's the only thing that makes sense at this point.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Sep 06, 2009
Somewhat Helpful)
hixsonkim
Rank: Apprentice
Rating: 81%, 4 votes
where does the dirty water go into? i useing a friends an he dont have no idea.. how this works can someone help.. i use it on a small carpet but nothing is going anywhere HELP
Was this helpful?
Yes
No
Solution #5
posted on Sep 09, 2009
Somewhat Helpful)
quadcam8
Rank: Apprentice
Rating: 75%, 2 votes
the bladder is ful? You need to dump it before it can pick up more.
Was this helpful?
Yes
No
Popular Solutions for Bissell 9500 ProHeat 2X
Questions and Unsolved Problems for Bissell 9500 ProHeat 2X
Do you recommend Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum?
Answer
Answer
how do i put belts on my momtook it apart and now i have no idiea how to put it baack on
Answer
bissell proheat 2x water coming out whether machine is suppose to be sucking up water or no which it... (More)
Answer
I am getting no suction. I am cleaning furn, have the seting on tools??? Solution will spray out.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bissell 9500 ProHeat 2X...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
