Question about KitchenAid Refrigerators
Water filter does not filter water
The water filter will not fill up with water anymore. We had a technician out a couple years ago who fixed the compressor. He also replaced our filter with one we owned. 6 months later I replace the filter to discover the one installed had not filtered any water. I used the new one for another 6 months and the same thing happened. It was completely clean, had not filtered any water. When I turn these filters in now, it is not easy like it used to be, and how the videos show to be. I have about 5 brand new filters and have tried all of them. None will work, all are hard to turn, they grind the plastic down. I read they changed some of tip of the plastic on the filters but they are the correct ones, and will work. I bought a new housing this summer, thinking the technician changed it out and replaced the wrong one. I was assured by Sears Parts Direct, that the housing and these filters go together and my problem would be solved. It is not solved. I still don't have filtered water. The original tech is no longer available. I had another tech come out and install one of the filters when he was here to repair the oven. But that didn't work either.
  • 1 more comment
  • Robyn Hood
    Robyn Hood Mar 27, 2014
    The filter is Whirlpool 4396508 and to clairfy where I said I had read about the tips being changed by the filter manufacturers and these are the correct ones PER the manufactuer, but they don't work.
  • Robyn Hood
    KSRB25FHSS02, my model, I don't see it listed but entered it. Lastly, the ice maker and water dispenser work great.
  • Robyn Hood
    Robyn Hood Jul 07, 2014
    To clarify, the water dispenser works great, the filter will not work, I had another tech look at it and he was perplexed, he tried two brand new filters to no avail. I am still unable to drink filtered water. :(
shaggyrat
  • 1224 Answers
SOURCE: Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
Posted on May 15, 2008
SOURCE: water filter housing leak
Leak just stopped on its own. No idea why.
Posted on Oct 11, 2008
SOURCE: GSH@%JSTASS - No water, Ice ok, Filter changed, defrosted...still SMART water is not coming
the first step for put the used my
frigerator
Posted on Oct 19, 2008
  • 78 Answers
SOURCE: Plastic Taste in Refrigerator Water
Hi there, I noticed the same condition when I left the filter in ours a little too long. The optimal performance from the filter is achieved (I have found) when you change it after 3 months. This is about the same amount of time it takes for the light to change from green to red on the filter light.
Hope this helps. ~Steve
Posted on Feb 25, 2009
projdoc
  • 2237 Answers
SOURCE: I have replaced my Frigidaire water filter with a
the seal on the filter cover- is it cracked, pinched, broken or missing? if so, get a new seal. if it's leaking from the tubes going to it, tighten them with a crescent wrench.
Posted on Nov 13, 2009
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
Oct 14, 2014 | Water Heaters
My 2 year old frigidaire dishwasher is not filling up with water, goes through cycle but no water is coming out, valve is open all the way?
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Click on : Inlet valve
Jan 25, 2013 | Dishwashers
The ice machine seems to work but the water won't fill anymore.
It could be one of three issues.
1. The water lines could be clogged with buildup.
2. If you have a filter it may be clogged stopping any water from filling the Ice tray.
3. You may have a short in the icemaker.
I would first check the water lines and/or change out the filter. This fixed the same issue on mine.
Mar 02, 2011 | Amana Microwave Ovens
Water flow is extremely slow after filter change.
Those filters are for refrigerators that have heavily treated water in the household. You could have a filter that filters your water supply and not use the filter inside the frig. Why use both? Now, if your home is not filtered, you may need it. Check to see if the water supply line is crimped somewhere or frozen when it gets inside the frig.
Jul 15, 2010 | GE Refrigerators
Bosch dishwasher not filling
you need to chech the inlet water tap,hose,filter i think the problem come from that.
thanks
Jul 09, 2009 | Dishwashers
Eco light keeps flashing won't fill with water
Something with the program module , get a technician if worthwhile.
The flow dection (expensive can't be) because pre wash gets water supply. Might be loose wire or broken button. Any handy guy around that can cautious open then model behind the panel and chreck connections. I fixed mine last year with a dot of 2 component glue because of broken switch. Unluckily, the flow detector broke after 10 years (interconnected with automatic water stop
Apr 15, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Dishwasher will not fill. Water lines have been checked and filters are clean
Flow detection shot?
Expensive one I had couple of months ago on a Bauknecht. 300 dollars. New machine at 250. Scrapped it.
Flow detector was coupled at automatic waterstop.
Beware if you have a old machine drying with hot air, most all new models use condensation leaving your dishes etc a bit bit wet :(
Apr 14, 2009 | Dishwashers
Toilet tank not filling
shut the water off to the toilet .Remove the toilet supply from the tank end.slowly turn the valve on to see if their is any water coming thru the supply.If water is coming thru the supply than you know you need to change the ballcock.This is the part in the tank where the water comes out of.
Feb 01, 2009 | Kohler Santa Rosa K-3323-0 White Compact...
Morphy richards jet stream iron
We have a water filter and softened water. Our iron is clean and went after 2 months.
A Morphy Richards Jet Stream Elite pro.
It is just the steam generator that has gone.
May 27, 2008 | Irons
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
