Question about Dell Precision Computers & Internet
Getting drive controller errors on dell optiplex 330 dt
Drive controller error on dell optiplex 330 dt. is this a problem on the motherboard or on the HDD itself. Would it help to shift connected from SATA1 to SATA2 or 3? Please help.
    Sergeant:
  • 240 Answers
First, check you hard drive as follows:
*Download Seatools For DOS (free) from my link; in the site screen, click "DOWNLOADS" tab, then "Seatools For DOS". Burn it to a CD. Reboot with it in your drive. In the screen that appears, first check that SMART has (or has not) been tripped. If it has been tripped, your drive is failing. Then click the upper left corner of the screen for the short test and let it run. It will notify you either Pass or Fail. This is from Seagate Corp. but will test all other drives, not just Seagate.
If your drive passes as good, the chances are that your motherboard is failing/failed. Try swapping your cables as you stated, but I don't think that will help. If you have an extra hard drive you can swap it to test, but if it is empty you will need some kind of operating system installation disk to see if you can load an OS on it. If so, then the hard drive is bad.
For more detailed and in-depth help, I hang out at www.suggest-a-fix.com computer help forum (free). Post in.
Posted on Mar 27, 2014
SOURCE: FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
Optiplex 150 I get a message error loading operating system
can somebody help out there?
Posted on Jan 06, 2009
ginko
  • 19396 Answers
SOURCE: ethernet controller
Here is the download page, you need to select model and OS: Driver & Download
Posted on Jan 12, 2009
oblivion2k
  • 150 Answers
SOURCE: Dell (ie optiplex 330) would not boot with the orange light on
Do you have a lot of accessories plugged in? They may have overloaded the power supply and if this is the case you will need to buy new power supplies. If this is not the problem, check to make sure that the computers have plenty of ventilation in the back. If they don't, they may have overheated and melted quite a few different components.
Posted on Feb 27, 2009
  • 23 Answers
SOURCE: my dell optiplex 330 can not switch on, whan I put
If you are getting an amber light flashing, your power supply is faulty.
If it is a solid amber light, you motherboard is faulty or one of the componants are faulty.
I would suggest giving Dell a call. They would beable to pin point the problem and give you a quote. Some of their componants are non standard and can only be purchased from them.
You could try reseating all your componants on the last resort but it is unlikly to help.
Posted on Jun 26, 2009
Current009
  • 135 Answers
SOURCE: Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
Posted on May 31, 2010
Dell error code 2000-0151 incorrect status 28
That error indicates an "incorrect status" of your optical drive. I suggest you run the Dell diagnostics on your drive. To test your CD/DVD drive from the utility partition:
1. Reboot your system. When you see the Dell logo, hit F12 to enter the boot menu.
2. Select Boot to utility partition.
3. Select Test System.
4. Select Custom Test.
5. Use the arrow keys or mouse to select your CD/DVD drive.
6. Insert a CD or DVD.
7. Click Run Tests.
8. Write down any error messages.
Feb 28, 2014 | Dell OptiPlex 390 DT Desktop Computer...
Dell Optiplex 330,won't boot memory parity error, tried new bios battery, new ram stick, still won't boot,actually had two at same time the other I ran a advanced diagnostic test said hard driv
I found this
Customer's Optiplex 330 did the same thing today; no beep codes (due to lack of on board speaker). Solid/orange light on front of case indicates board or cpu. I isolated every component not soldered down (RAM, HDD, Optical, etc). Considering all the fans and lights on the MoBo were functioning, and no physical damage to the CPU was apparent, and the BSOD presented the "memory parity error; system halted" (meaning it's memory, graphics memory, or cpu and we've eliminated possibly CPU and RAM) my conclusion is that the problem resides in Graphics memory failure. Considering the error message is very vague and generally insists "motherboard", the gpu in an optiplex 330 is integrated ON the board, lumping it all together.
and general memory parity fail information
memory parity error fix Google Search
Nov 22, 2017 | IBM ThinkCentre Computers & Internet
Were do the jumpers go on a optiplex 330
There is the Password jumper (PSWD), and the CMOS jumper.
The CMOS battery is also termed the RTC battery.
Real Time Clock battery.
The CMOS jumper is labeled as RTCRST.
Real Time Clock ReSeT.
Jumper pin location is confusing if you go with Dell documentation.
http://support.dell.com/support/edocs/systems/op330/en/ug/mtparts.htm#wp1607303
Dell Support documentation shows the RTCRST jumper pins near the Intel chipset, and PSWD jumper pins near the outside edge of the motherboard.
I'm also looking at the Dell Optiplex 330, Technical Guidebook, Inside the Optiplex 330,
http://www.dell.com/downloads/global/products/optix/en/optix_330_techspecs.pdf
Location of RTCRST jumper pins, is near the left corner of the Intel chipset, instead of the right as shown above, and PSWD jumper pins are in the same location.
And several views of Optiplex 330 motherboard's on Ebay,
http://www.ebay.com/itm/Dell-Optiplex-330-Motherboard-Socket-775-KP561-/140870576837?pt=Motherboards&hash=item20cc8a6ac5
(Nice to have that Zoom in feature on Ebay now)
Jumper pins close to the white SATA 2 connector, are the RTCRST jumper pins.
Jumper pins at the bottom side of the Intel chipset are the PSWD jumper pins.
Jumper cap stays on PSWD jumper pins.
No jumper cap on the RTCRST jumper pins.
http://en.community.dell.com/support-forums/desktop/f/3514/p/18683374/18806360.aspx
Regards,
joecoolvette
Oct 23, 2012 | Intel Motherboard
When i start my dell optiplex 330 pc, the power light will be blinking orange and all the fans on the pc do not work but the orange led on the motherboard works.
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Sep 16, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
I get orange light on my power button when i power my dell optiplex 330 pc
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Flashing Amber, bad power supply
Solid Amber either a bad component connected to motherboard of the motherboard itself has failed
Jun 23, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
May 31, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Pixel shader error 06 on my optiplex 330
Graphics Card
Minimum Requirement
VRAM (256 MB)
DirectX 9.0c / Shader 3.0
NVIDIA GeForce 6800 series
ATI Radeon HD 2400 Pro
Your Dell has an Intel GMA 3000 onboard with up to 256 MB shared memory and isn't listed so probably isn't supported.
Mar 17, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Computers & Internet Logo
59 people viewed this question
Alun Cox
