The fan on the bottom of the laptop is not spinning so my laptop overheats in about a half hour and shuts off by itself.
Is there something wrong with the software?
    Top Expert:
  • Computers & ... Master
  • 26,775 Answers
Try cleaning and or replacing the fan.
Posted on Mar 27, 2014
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
The laptop word is actually wrong, the passage of the fan will be blocked that is for cooling. If you keep your laptop on bed it will suck the cloth lint and fan revolutions will be hampered that means no cooling. Your laptop is stopping due to stuck fan and overheating. If you can access the fan and try freeing it from hairs and lint then your problem will be solved or call a local computer guy to open the laptop and free the fan of lint .
saqeb
  • 47 Answers
SOURCE: laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Posted on Jan 27, 2009
  • 272 Answers
SOURCE: LAPTOP OVERHEATS AND COMPLETELY SHUTS OFF
Have you cleaned it lately? If not that's what they sell those cans of compressed air for. With your computer off bloe the air through all of the vents you can locate to get all of tha accumulated dust that is blocking the airflow out of there!
Posted on May 25, 2009
sharksupport
  • 14 Answers
SOURCE: overheat?
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Posted on Nov 28, 2007
DJ Wildman
  • 10 Answers
SOURCE: toshiba A65-S1062 - This laptop overheats and shuts down.
I bet that you had your laptop on all the time.
Your heat sink is saturated with dust and grit.
you may have to open up the unit and use a can of dust remover to clean the fins on the heat sink out. it is causing your CPU to shut down bucause it is becoming overheated.
Happy Fixing =)
Posted on Jul 11, 2009
  • 788 Answers
SOURCE: ACER Aspire 5720 overheat problem?
Try to keep as much ventilation under the laptop as possible.
You can pick up a can of power spray and blow out the unit yourself or have a pro. do it for you.
Dust and lint play a deadly part in overheating with laptops.
Walmart has Ventilation trays in which the laptop sits and is cooled by forced air from underneath.
Make sure the direction of air flow is the same as your laptop.
You dont want to push air into a output vent.
Posted on Aug 30, 2009
Overheat and shutdown hp mini laptop
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 06, 2013 | HP Mini 1000 Netbook
My sylvania mini laptop windows ce wont stay on
Feb 26, 2013 | Sylvania G-Netbook
My acer laptop is in on state only for about 1 hour.It gets shutted down then.What can be the reason.Do I have to change the battery or motherboard?
Dec 29, 2012 | Computers & Internet
I have a HP 6735s and was using it today. After about half a hour the screen went black and the laptop powered down. I tried another power cable that I have and also a battery but the laptop constantly...
The laptop maybe overheating.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 22, 2012 | HP Compaq 6735s Notebook
What would cause my aspire 5630 to shut down sporadically?
Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
Possibilities and solutions
1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
2. The possibility of fan processor die.
Solution: replace the processor fan.
The characteristics of damage to the processor fan
After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
How to check
Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
- Normal temperature, when first turned on + - 38oC
- Normal temperature, after turn on for hours 40oC - 45oC
- Temperature overheat processor, when first turned on 60oC - 65oC
Nov 18, 2011 | Acer Computers & Internet
When i switched on my laptop,it showd the warning as cooling fan is not workingproperly.and it got shut down automaticaly within 10 sec. but there is another option present showing start windows...
The computer monitors the speed of a fan inside your laptop.
If the fan stops spinning, or is spinning too slowly to cool your computer, your computer will stop.
Take your computer to a qualified technician, before your computer overheats and REALLY damages itself.
Apr 20, 2011 | Computers & Internet
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
My laptop gets heat and shutdown
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
Feb 27, 2010 | Compaq Evo N610C Notebook
ACER ASPIRE 3000 gets power off after some time automatically
If the laptop shuts down by itself and deosn't boot up again after some time, then the problem could be an over heating problem. The CPU shuts down when it overheats (thermal shutdown) and it is usually caused by a faulty fan and or the fan and heat-sink is clogged with dust.
Check the fan and if it does not spin freely then replace the fan and or remove the dust from the fan and heat-sink assembly.
Oct 12, 2009 | Acer Aspire 3000 Notebook
Turns itself off & gets hot -don't think fan is kicking on
Since you do not hear the fan anymore I would start by opening up the case and seeing if power is going to the fan and make sure any connectors for it have not come loose. If the connectors are still hooked up chances are the fan is shot and needs to be replaced.
If you are not familiar with working around electronics and parts under power I would highly suggest you have some one who is familiar with this do it.
May 06, 2009 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
