Question about Kensington Computers & Internet
Space bar popped off how do I put it back on?
My space bar popped off. How do I put it back on?
  • Rita Roberts
    Rita Roberts Mar 27, 2014
    It's a Kensington wireless bluetooth keyboard
  • 128 Answers
If nothing is broken, then try to put it back to it's pevious possition, tush gently down, until it clicks....do not use much power...
Posted on Mar 27, 2014
Thespacebarwon'twork!HELP!
did you try to pop the space bar off and clean it and put it back on it should work then
Feb 05, 2014 | Perixx PERIDUO-703W, Wireless Keyboard and...
When I hit the spacebar it jumps 2 spaces
Look closely at the space bar. try to lift it on the right side and on the left. The bar may have popped out of place. Specifically a metal rod that holds the space bar in place. Or the space bar is not resetting fast enough, ( soda, honey, something sticky) causing the bar to reset slowly.
Nov 01, 2013 | Lexmark Wheelwriter 10 Series II...
O want to install a new key . What are the steps ,please
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
b>
Jan 16, 2013 | Computers & Internet
THE SPACE BAR ON MY LENOVA y530 CAME OFF- HOW DO i GET IT BACK ON?
You could try pressing the space bar key back into position since it has a small clip on the same part where the space bar key was held in position and incase if the key still pops off you would need to contact technical support to get the keyboard replaced.
Jun 01, 2010 | IBM Lenovo ThinkPad T61 Notebook
The space bar has come off how do i fix it
Often with keyboard keys, they have several clips that hold the keyin place. Try gently prying the key off again, and see if there is any placewhere the plastic might have broken, or if there were other clips thatweren't quite in place. If the key is broken, though, you can either deal with it as it is, orprobably order a new key.
Jan 07, 2010 | Sony VAIO PCG-K23 Notebook
Spacebar on IBM Lenovo ThinkPad X61 came off.
I took mine off to clean under it and had a similar problem. After a bit of struggling I figured it out. I will try to explain it as best as I can, but forgive the non-technical language:
There are two gray plastic pieces on the space bar that must be that must be latched to the two white plastic pieces on the computer. The gray pieces pop off the space bar easily. Take them and put them on the white pieces on the computer so that the white arms lay across (and snap into) the top and bottom of the gray piece. The middle of the gray piece will sit in between the two arms that are not "holding" the gray piece. Then take the space bar and put the metal part into the hole on one side (outside of the plastic pieces) and then push it over so you can put the opposite metal part into the other side. Then push the space bar straight down and it will snap into place.
Apr 12, 2009 | IBM Lenovo ThinkPad T61 Notebook
Took spacebar off to clean up a pop spill...metal bar NOT attatch
There might be a metal wire if it is missing, which snaps to the keyboard, you may need a new keyboard.
If you are unsure, you should probably thake it to your local computer repair shop.
Good Luck.
Mar 15, 2009 | IBM ThinkPad T42 Notebook
Keyboard space bar
turn your keyboard upside down and tap it a few times. if that doesnt solve the problem repeat.
If it still won't work write back for more ideas.
good luck and please rate my answer. thanks.
Feb 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Space bar sticking on Saitek lighted keyboard
For me, I popped of the space bar, cleaned the junk underneath and fidgeted with the plastic push-button and all was better. Thanks for the suggestion!
Feb 21, 2008 | Saitek Eclipse II
Fan noise and space bar issue
Heyo, the fan needs to be cleaned. Your environment air may be the culprit...if that is the case, I am sure the space bar is doing that for the same reason. If you can afford to take it to the shop to have the shell taken off and cleaned properly, I would do it.
Jan 03, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
rey francis basa
rey francis basa
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
