Question about LG LFX28978ST 27.6 Cu.Ft. French Door Refrigerator
Water dispenser Water will not come out or fill the ice cube tray.
    Problem Solver:
  • 8 Answers
Make sure the freezer door is closed
Make sure the water is turned on, a valve on the wall behind the frige.
Make sure the filter is good.
Posted on Mar 27, 2014
  • Amy Robinson
    Amy Robinson Mar 27, 2014
    Thx. I took out the filter and reinstalled it. Now the water dispenses without any problem.
Why are the cubes not breaking apart when dumping from the tray?
It is over-filling and the cubes are fused together... If the fill is adjustable, lower it, but you may need a new water valve... Frigidaire Water Inlet Valve 242252702
Jul 31, 2014 | Frigidaire FFSC2323LS 22.6 Cu. Ft....
Ice cubes wont come out when the dispenser tips it upside down
The ice mold tray has built up deposits that "glue" the ice cubes to the tray. This usually means you will have to change the mold tray. You could try vinegar or lemon juice to clean it but the trays are not that expensive.
Apr 12, 2014 | Refrigerators
Ice tray not filling
The unit will not allow water to enter the frig til the temp is cold enough to make ice.
Nov 06, 2012 | Bosch Refrigerators
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
Problems with ice maker
Bsbbj,
If the cubes are fusing together (such as when you overfill an ice tray), your solution could be as simple as adjusting the fill volume (there should be an adjustment under the front plastic cover, and the cover should just pop off and snap back on unless you see screws attaching it) and when your ice maker was replaced this probably wasn't calibrated correctly. Your mention of the side of the maker bulging also leads me to believe the water is overflowing and freezing within the dispenser (causing it to bulge and not dispense).
I hope this helps and Good luck.
Mar 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Jun 11, 2007 | Samsung RS2630SH Side by Side Refrigerator
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
LG LFX28978ST 27.6 Cu.Ft. French Door Refrigerator Logo
44 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
