Radio on safe mode
SOURCE: radio safe code needed
You should have been given the radio code for the vehicle when purchased, if not you will have to visit your local audi dealer for them to obtain the code from germany, check your audio handbook to see if the code is in there
SOURCE: 1998 Audi A6 Quattro radio in safe mode
Er. That is why it is a *code*.
"There can only be one".
If you have no pin code you will have to pay the dealer to look it up in the database. If your radio is in the original vehicle, that should not be an issue.
I have never heard of anyone successfully 'hacking' an Audi radio code....
SOURCE: 2001 Audi A4 radio in safe mode. Battery was
sorry to say, you will need to take it in, it needs to be hooked up to their computer to reset and have it start up poperly. It just like a pc when it crash it will try to start in safe mode until you select "Normal" start up
SOURCE: Safe mode in Audi Symphony radio
hold rbds and pscan till you see numbers then use the radio memory buttons to control the number you want to put in after the numbers are put in hold rbds pscan again till u see it says safe and radio works.
SOURCE: my radio is in 2
IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for Audi radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
