Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Start button collapsed
Pushed the start button and the button underneath collapsed. Now I can't start the wash because there is nothing below the start button to push.
    Sergeant:
  • Whirlpool Expert
  • 243 Answers
There is a control module behind the button, maybe the screws became loose and it is falling away.
Posted on Apr 11, 2014
  • 53 Answers
SOURCE: green start button does nothing when pushed
Replace the analog pressure switch. Remove the top of the machine to access. Located on the right side I believe
Posted on Oct 15, 2009
  • 109 Answers
SOURCE: The cycle doesn't start
This could be one of a couple of differnt things,one is the switch is bad, 2 a wire is broken - 3 the timer is bad or you have a dead short which should if properly grounded will throw the breaker or fuse
Posted on Aug 22, 2009
SOURCE: Front Loading Duet Washer will not start
I've got same problem, with the door stuck shut, door lock NOT on, water trapped in the machine, and still no solution. 8 pages of messages and no solution.
Posted on Mar 14, 2008
  • 1382 Answers
SOURCE: My front loading washing machine
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Posted on Aug 13, 2010
  • 87 Answers
SOURCE: the power went off while
Hi
What you can try to do is unplug washer for one minute and then power it up choose a cycle and you should hear the door mechanism unlocking
hope this helps
Posted on Mar 27, 2011
My westinghouse LT608S wont start washing cycle. washer turns on ok, then when i press the start button to start washing it keeps beeping at me, and the 2 lights on the 'water level' section are flashing....
Westinghouse lt608s...I had the same problem that when you pushed start it would just beep and the water level lights would flash...i fixed this by replacing the magnet underneath the lid. To test if this is the problem place a magnet about a third of the way up ion top of the lid on the left hand side and then press start. If it starts then you know the magnet that is supposed to be underneath the lid is either broken and missing or rusty...anyway i hot glued mine (as i do not use hot wash) back under the lid and hey presto it worked fine.
Feb 16, 2011 | Washing Machines
Left click button has colapsed on HP G60-535DX laptop/notebook
I had this happen with a Compaq CQ70....The palmrest has to be removed and in most cases the retainer for the button can be pushed back into position from underneath. At the very least, the button assembly may have to be replaced. Is it still possible to activate the left click even though the button is collapsed? If not, the problem maybe the collapse of the actual button assembly on the circuit board under the plastic button assembly. Below is the link to the service manual for that laptop. The link below is named cq60 etc, which is the HP cousin of the G60. They are exactly the same like Chevy trucks and GMC.
http://www.insidemylaptop.com/remove-motherboard-from-compaq-presario-cq50-cq60-cq70-laptop/
Jun 18, 2010 | Computers & Internet
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
and push the start button
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Nov 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not turn on
If led'slight up when POWER button pushed but nothing happens when START button pushed ITis likelt to be lid reed switch open circuit or pump is open circuit .If nothing lights up when turned on at wall socket suspect controller dead or pump open circuit.Pump sounds like it has caused problem joker 120 need to check loop resistance of pump 35ohms for Aus/NZ
Nov 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
236 people viewed this question
Dan Webster
Dan Webster
Sal De
