Question about Sharp LC-32SB21U 32 in. LCD TV
Lc-32SB21U black screen
Has audio but no video
    Problem Solver:
  • 14 Answers
There is no back light check the inverter or resistor near the inverter
sometimes its open or change of value
Posted on Apr 21, 2014
  • 208 Answers
SOURCE: No Video on Sharp Aquos LC-46D62U
Have you check all inputs as the HDMI inputs and the composit inputs are processed on a different bd?
Posted on Feb 26, 2008
dsacco86
  • 1077 Answers
SOURCE: I originally purchased a LC-32SB24U and wound up
Don't feel bad. You didn't do anything wrong.
They sent you a TV with a bad power supply board for the
screen. The TV is trying to power up the screen, but it can't. Because of a defective part somewhere on the power inverter board for the screen. That is why the power/opc light is flashing.
I would call them back and and make them replace the TV.
Posted on May 16, 2009
tvservice306
  • 458 Answers
SOURCE: need a sharp 32 LC-32SB21U screen
Manufacturer Sharp Part Number LK315T3GW30R Description 32" VE PANEL ASSEMBL
Posted on Sep 05, 2009
taran_2005
  • 10515 Answers
SOURCE: Remote function on LC-32SB21U stopped
This is a common problem with Sharp LCD models. This seems to be a faulty IR circuit. A simple solution that sharp gave to their customers - unplug the TV for few minutes, say 15 minutes and then plug it in. Most of the times it would work.This is more of a design fault as there is a problem with IR circuit that somehow freezes and needs a reboot. They have certain upgraded firmwares for the same. It could be due to faulty IR sensor ( though rare possibility ).Unfortunately, this is not a DIY and you need to call Sharp.
Note - This is a common problem and Sharp is aware. Calling a local tech would not help as this has to be taken care ONLY by Sharp.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
maatmartin7
  • 1210 Answers
SOURCE: sharp tv difficulty starting. Will
I have not worked on this particular model. But, I wopuld certainly say you have a couple of bad capacitors in the power supply. You will need to remove the back cover. Weak or bad capacitors will cause your TV to do exactly what you describe. You may note these capacitors will be bulged. The values may or could be 35 volts at 1000Mfs. Once again, I do not know the exact values. In most cases these capacitors in many other brands will have this value. This info is a very good start for repairs. Hope this will clue you into a repair. Thanks for asking and show all hands of support!
Posted on Aug 31, 2011
How to change aspect ratio on sharp tv?
You cant change the aspect ratio. You can stretch and zoom programs . Some programs like movies are in letterbox and you can stretch to fill the screen, but the results are not perfect. Circles will be oval and you will cut off some of the viewable picture. This is normal
Jun 29, 2014 | Sharp LC-32SB21U 32 in. LCD TV
Sharp LC-32SB21U 32 in. LCD TV poor audio
The main board is having issues eventually the sound will drop out altogether. Replacing the main board should solve the issue. You can get the main board from www.tvrepairworld.com
Oct 03, 2012 | Sharp LC-32SB21U 32 in. LCD TV
Sharp tv difficulty starting. Will come on and immediately go off .Audio stays on screen black. this happens over and over. Banging on the on/off button works sometime. Once on it stays on indefinately....
Aug 31, 2011 | Sharp LC-32SB21U 32 in. LCD TV
When i connect it with play station2 it display games without color
Checked the connection of your play station to your LCD t.v. it should be connection properly to video input,try to tightening the connection between them and also check the settings of your LCD t.v. if it is actively in colored t.v. settings.
Jul 27, 2011 | Sharp AQUOS LC-32SB21U 32 in. LCD TV
I have a Sharp AQUOS LC-32D47UA 32", black box
Press the cc button on your remote control. You want cc to be off. Play around with the cc button to become comfortable. Press it over and over again. Observed that a different closed captioning option appears on your screen each time you press the cc button. Now press cc and when it says cc off do not press the button anymore.
Jan 23, 2011 | Sharp LC-32SB21U 32 in. LCD TV
Audio keeps switching from mono to stereo
on every channel ? then av board is failing
on a single channel then it is their signal not you set
Nov 24, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Need a sharp 32 LC-32SB21U screen
Sep 04, 2009 | Sharp LC-32SB21U 32 in. LCD TV
I originally purchased a LC-32SB24U and wound up needing a replacement because there was a black line going accross the top of the screen. Sharp didn't have any of that model so they sent me a LC-32SB21U...
May 16, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Feb 26, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LC-32SB21U 32 in. LCD TV Logo
75 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
